10 inch wide wheel offset?
  • 10 inch wide wheel offset?
    so my 15x8 with a negative 6 offset plus my inch and a half adapter i was told is around -30et by oxer back in the day, Now if i were to order a 15x10 what would be an almost equal offset so the wheel would poke the same?
    Thanks for any help guys
    HoodRatStatus
    Instagram @looneylow
    -6 + a 1.5" adapter is -44offset
    he mustve enjoyed that bj.
      works magic.
        15x10 -5 (negative 5).
        if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
        Originally posted by Jedidiah
        he speaks the truth.. he doesn't even have the -- -- eyes.
          Please don't again.
          - Kielan (Key-lin)
            Now if you want the same poke you'll be running into Inner clearance issues. to get the same outside poke you;d need a 15x10 -20offset, but you're wheel would be 2" closer to the strut.
              that'll be sunken half an inch.
                I was going off 15x8 -30 vs 15x10 -5
                Reading > me.
                  Reading > me.
                  its ok. it's austrailias fault.
                  i use this site
                    so im going to need a -20? and your saying that will be close to my strut? so i would need to measure 3.5 inche in from my current wheel setup to make sure i have clearance right? 1.5 inches for the adapter and 2 inches closer because its a x10? correct if im wrong please
                    HoodRatStatus
                      Right now, Measure how much clearance you have from the rim to the strut. And are you going to continue to run the adaptor?
                        no adapter,this one is all wheel i had the adapter to be 5 lug, im buying 4x100 15x10.
                        right now im running a 15x8 with an inch and a half adapter, i want to just run a solid 10 no adapters or spacers
                        HoodRatStatus
                          ok then yeah 15x10 -20offset. but it will stick in 2" towards the strut from where your 15x8 is now. but the outside will be the same flushness as before.
                            What car are you putting this on?! Love to see it...
                            91' TT - Mines ECU, Blitz SBC@1bar, ARC WMIC, 2.5" decat, 2.5" ProFlow Exhaust, HSD's, ls400's, JapanRacing JR12's. SoarerUnion.com
                              some crappy honda civic with too many stickers and screwed up fenders... they way i see it im basically at a 9.5 right now so whats another half inch right? good idea or bad, im doing it
                              HoodRatStatus
