Corvette multi-piece wheels. Need help from e36 stance-gods.
  • #16
    Originally posted by Spiff View Post
    hey there, im considering to get some corvette wheels for my E36, do i have to get adapters for this custom made? how big is the adapters you run on your car SeanDub?
    how bout you do some research?
    its not hard, figure out what "corvette" wheels you plan on running (width/diameter and offset) then figure out what "finished" offset you wanna run and get appropriate adapters... a little reading goes a long way
    BalleurBuilt•DSDone
    form>function
    "i mean we cant even rock dem shoes if it dont got a comma on the price tag..."
    • #17
      i know what i wan tto run with, im just asking to see if i need to locate someone whohave to make the adapters for me, or if there is some shop i can get something that wil work for me, and also cuirous about what SeanDub uses on his car, i guess he got 33mm in the rear from what i have read, but im not sure about the front end..
      www.bimmers.no
      If something's hard to do, it's not worth doing. -Homer Simpson
      • #18
        Like I said all of that depends on the width of the wheel an the offset, there are tons of adapters and spacers available online you will not need someone to custom fab you a set you just need to find out how big of an adapter you need and for that you need to go and measure your car or just guess ad go through trial an error like most of us do
        your asking a question with little to no details about what wheels you wanna rub so how is anyone supposed to help you?
        BalleurBuilt•DSDone
        form>function
        • #19
          Originally posted by M.Burroughs View Post
          Much better wheel option than the blue ones.
          You got something against blue wheels?
          • #20
            most likely i will be getting sawblades, 8,5 and 9,5 both ET56 as they seems to be the most easy wheels to get in norway, i was thinking to get the adapters in front to end up with ET13 and in the rear im a bit more unsure, but i think that around ET 20-25 somewhere.
            what is the spec on the wheels you are running?
            www.bimmers.no
            • #21
              This is what you need..
              * Adapter Lug Nuts Included* Price Is For 1 Wheel Spacer* 2 or More save $10.00 per Adapter* All Adapters and Spacers are made to order, 7-10 business days to your door.* Limited Warranty~Non-Returnable
              1.30 in the rear will put you at +22
              and 1.80 in the front to put you at +11
              BalleurBuilt•DSDone
              form>function
              • #22
                great, thx!
                www.bimmers.no
                • #23
                  so fvcking jealous of these wheels and price paid for.
