Need help to fit my gotti on my e30
  • Need help to fit my gotti on my e30
    i have a set off stagger gotti
    15x8 F et 0
    15x10 R et 50
    but the problem is i need adapteur to fit 4x108 to 4x100
    i want to be flush in the front and poke the rear
    i was thinkin of -15 front(i thin is to much to be flush)
    and 15 in the back.
    And for the tire 185 45 on the 8
    and 195 50 on the 10
    Give me your opinions
    THANKSS
    Back will be about as close to flush as you can get on 15x10's, stick with that. Front will poke a little over half an inch up front, no way you can get those flush without redrilling them.
    Rear tire size is good, front is too short. If you can find 185/50's go with them.
      I do a test fit today! and wayyyy tooo much poke in rear
      what can i do?? i will redrill for sure but what else
      the are the last one
        Lol you messed up somewhere with your measurements. They will tuck in a bunch once you load up the suspension and get some camber going but that still doesn't look like et15
          the offset is supposed to be 50 in the back i dont run adapter for the moment and i think to refill and redrill the wheel for less poke.
          do you think i gonna poke like thise when de coilver and the camber will be on?
          I DONT WANT MEXIPOKE ahahha
