fitment help
  • fitment help
    i need help.... i currently have 17x7 +40 in the rear..
    im looking at a set of wheels that are 17x9 +30
    basically will they fit?
    KINGSTONPHOTO.NET
    2005 Kia Spectra5 Build
    On what?
      Originally posted by kartikeya View Post
      On what?
      LOL Exactly.
      How much room do you have from where your current lip ends to where the fender edge is? Measure that and it'll give you a really close idea (assuming you'll stay at the same height that you're measuring at).
      E12/E39M/E53
        Kia spectra5
        KINGSTONPHOTO.NET
          it will EXTEND an extra 30mm
          KINGSTONPHOTO.NET
            and with my tires on the new wheels it would "look" like this
            KINGSTONPHOTO.NET
              Well right, we know that. What I meant was how much room do you have between where your wheel sits now and your fender edge? It's kind of hard to tell from that one picture, but at that ride height it doesn't look like it'll be a problem.
              E12/E39M/E53
                You should also take a look at how much room you currently have between your inside wheel lip and your strut.
                E12/E39M/E53
                  looks like about 1 1/4" gap. from current rim to fender
                  KINGSTONPHOTO.NET
                    1 1/2 from rim to strut
                    KINGSTONPHOTO.NET
                      Then at that height you're good to go!
                      E12/E39M/E53
                        what are your thoughts on a 1/2" lower?
                        KINGSTONPHOTO.NET
                          Assuming your measuring your lip to fender gap correctly, then you should be able to drop it just fine without a problem. As you lower a vehicle you increase negative camber which will just tuck the wheel even further from the fender edge. But, I think as you go lower you'll start to notice your wheels sit more and more sunken in...which most people work to get rid of with spacers.
                          E12/E39M/E53
                            ok cool.. i have some 5mm spacers and i wanted some - camber so i might go for the wheels
                            KINGSTONPHOTO.NET
                              I know absolutely zero about the rear suspension on a Spectra, so I don't know how much (if any) rear camber adjustment you have. But I would highly recommend an alignment if you do plan on trying to dial in some rear camber. Just my $.02.
                              E12/E39M/E53
