Wobble Bolts Q
  • Wobble Bolts Q
    Yes, I am noob. Flame suit on.
    I have an Audi with 5x112 PCD. Wobble bolts allow me to put on 5x114.3 w/o adapters?
    How? Someone care to explain?
    -Peez
    i run 5x114 on my a4 using wobble bolts, so yes it will work. i got mine from raderworks, they used to have a video showing how it works but i cant find it anymore.
      they work by having the threads move independently from the actual head of the bolt. this allows the tapered part of the bolt to sit down inside the wheel, while the threads are not actually centered inside the wheel.
        i found a different viedo [ame="http://www.youtube.com/watch?v=adWfw2a-U6M"]http://www.youtube.com/watch?v=adWfw2a-U6M[/ame]
          Thanks for the vid
          AmberLamps..... Get rid of them!
            Safety concerns?
              ive never had any issues with mine, i used to check the torque on them weekly but i stoped since it was always were it was suposed to be.
                114.3-112 = 2.3mm total difference. That's 1.15mm difference each way. You'll be fine.
                if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
                Originally posted by Jedidiah
                he speaks the truth.. he doesn't even have the -- -- eyes.
                  where do one find wobble bolts?
                  www.stancefactory.com
                    perfect because i have 114.3 and my new wheels are 100/112
                      some multi lug wheels require tuner lugs/bolts...in that case you can't run wobbles, i sold my set so i cant measure em up on the outside to see but to be honest i doubt they will fit.
                        wobble bolts are safe, I think saab uses them on their cars?
                        E53 4.4 Sterling Gray Metallic
                        E36 M3 Mugello rot
                        GEN2 TUNDRA CM
                        https://instagram.com/carlmichaeljohnson/
                          Saab uses the lose seat because they had a problem with rims cracking, and they are not that wobbly.
                            Hey guys, I'm to This forum too, sorry :s but does this mean vw 5x100 cars can use vw/Audi just by using wobble bolts and no adapter :s , tiny bit confused.
                              No 5x100 to 5x112 is too large a difference for wobble bolts to handle
                              but 5x112 to 5x114.3 is possible with wobble bolts.
