hello i have an 86 635csi with 17 by 8 1/2 and 13mm offset with 2 and a half inch lip all around and i am running 15mm spacer in the rear which makes it a negative 3 in the rear.
i would like to run 18 by 8 and a half in the front and 18 by 10 in the rear with 2 and a half lip in front and four in the rear what offset should i run to have a little bit of poke so i can do a light stretch up front and heavy strecth in the rear the lip size is what throws me off 4 inch in the rear with what offset? i will keep lip size the same in the front 2 and a half thirteen isnt bad offset for now it can go a bit lower i really need numbers thrown at me i am ordering rims with custom lip size and offset.
