So I have a s13 and the wheels specs are 15x10 with a 0 offset and the tires are 205/50/15 and the fronts are 15x8 also with a zero offset on 175/50/15.Right now it is has alot of wheel gap.Sooo i;m wondering if when I lower it will it sill in the gap or should I start looking for new wheels.I'll get some pics later
s13 fitment
175/50-15 is very short for an S13- even 205/50 is technically too short. You may be able to tuck a bit of tire in the rear, but your car will be touching (or very nearly touching) the ground before it tucks in the front.
If going for a vintage small-wheel look with no tuck, it can be done with 15" on an S13, however, to get a flush fitment with a low profile tire and no gap, you ought to be looking at 17"+
pics of car? 15x8 should be spot on. Maybe it's cause of the stretch, but I think it'll be better if you lower it.
and the red 240 had 205/40 iirc.|My Blog|flickr| Currently own: '96 S-10, and '97 Maxima; Soon to own: '95 S14
Originally posted by DuWerkDrama you are like godOriginally posted by SwearBearLol, yes its a 5 speed manuel. I **** automatic >.< And just because its a kia doesnt mean it doesnt have guts or power. 273whp with extreamly very little done to it like less then $100 done to it.
Feel free to post other low S13s, but considering Yuta's engine was touching the ground, it was lower than most. For the purpose of the post, it works.Originally posted by cardoza View Post15x8 et 0 will be pretty spot on for the front, but 15x10 et 0 will be some pretty major poke.
Also, that 240 posted above is definitely not one of the lowest...
considering that this guy was laying the whole underside...Originally posted by kartikeya View PostFeel free to post other low S13s, but considering Yuta's engine was touching the ground, it was lower than most. For the purpose of the post, it works.
get some X/55/15 tires and lower it more. You should be fine if you lower it.Originally posted by integra08 View PostSide view
true that would look good but again i don't think he can, with the exhaust he has now, and 15s are to small i think if your trying to get a good fitment and again that is my opinion feel free to do what ever you like.Originally posted by cardoza View PostBring it down like 3 inches all around and you'll be good to go.
