any other suggestions? not trying to do that
Stretched tire horror stories.....
Originally posted by alexis300 View Postsorry to bump an old thread. but i am having problems with my stretched tires. its not that dangerous tho. i am running nankang ns-II 215/35/18 on xx 527 18x9.75. the tires keep popping of their bead when driving aggressively. i run 50 psi btw. any suggestions? its getting really annoying thank you -Denisif not willing to compromise then this is the solution.Originally posted by Lukey View Postdont drive so hard
Its popping off because the side wall is too small/stretched too far.
What type of car is it? The weight of the car is probably a big factor aswell. Only way to do it is to run a bigger sidewall. If you aren't willing to use the advice that has been given in this thread, Good luck to you, because every other forum would laugh at your problem.Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
I had 165/40's on 8's and 7.5's only probem i had was the tyres going flat when I aired out (tyre got pulled off the rim when the wheels tucked in)
also ran 195/40 on a 9...no stress. just keep em pumped up! I run 40 in mine just to be safe
[QUOTE=Oxer;1593769]I Love VW's[/QUOTE]
its an is300. yea i guess imma have to go up to 40 sidewall next summer. thanks for the advice.Originally posted by Oxer View PostIts popping off because the side wall is too small/stretched too far.
hey daniel when did u become so mild man?Floccinaucinihilipilification
im rather new to all this tire stretching thing and was wanting to know what your guys opinion was on stretching 195/55r15s on a 15x10 rim as a daily driver. so far ive seen no problem with stretching and of course common sense with maintaining good tire pressure. would i be in the clear running this tire everyday? and im sorry if this was such a noob question
I too would go a 205/45, 195 is a bit too narrow and you will run into issues.
a 205 on a 10 stretch's nicely, if you need a 195 for clearance, id suggest different offset/narrower wheel.Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
