Widening rims?
  • #16
    Originally posted by extol1337 View Post
    Widened 2 inches on the inner side? You're still going to have to run spacers if that's the case.
    The way the wheel is it can't be widened on the outside. And spacers aren't an issue, there is alot of room already in the rear fender well. And if need be I can work some magic on the fenders
    1990 Mercedes 300CE- 24 valve
    • #17
      Originally posted by Hillbilly View Post
      But it's the rim that he's interested in widening. I'm usually with you on the wheels/rimz thing, but here I believe it's appropriate. somewhere on teh webz is a guy that has made a set of bottlecaps into a 3piece, he had an industrial machine shop cut the barrel and lip off and then drill it so he could bolt aftermarket lips/barrels. dopeness followed.
      edit: found 'em
      If it has to do with wheels, tires or brakes it goes here. 'Nuff said.
      Like I said, dopeness.
      Do you guys know where I could get inner and outer barrels for a reasonable price?
      The more I read into this diy multipiece wheel the more do-able it seems
      • #18
        sorry about my question, but this topic makes me wondering again...
        can i (somebody) make my amg monoblock wheels wider, but i mean wider lips?
        flickr
        • #19
          We Fuck Shit Up
          Shit box Sketch10 burnout truck.
          • #20
            someone recommended this guy, but he's clear on the other side of the US (but right up the street from me)
            Check out http://ericvaughnmachine.com! Aluminum Wheel Widening and Narrowing by Eric Vaughn Machine
            • #21
              ^^^Word, amazing work. I'm going to take a pair there.
              • #22
                in that thread didn't the guy have an industrial machinist do the cutting, drilling and machining on very large/expensive equipment? Not exactly my definition of diy...
                Originally posted by Sergey View Post
                Thanks! Many have security concerns and no doubt it might be an issue. my friend who is maritime engine engineer working at local ship engine metalworks (thanks for lending the mill) made some calculations that showed it would hold. The orginal made by ATS for Mercedes-Benz wheels are forged wich played a major part in this project. Cast wheels wouldn't hold.
                I will glue the rimrings with structural bonding so they aren't quite split after that.
                For a curiosity the mountingface is 7mm thick (just over 1/4") wich actually is 3-4mm thicker than the thinnest point on the stock ATS wheelbarrel (they are really light). I have had some japanese forged 15" wheels wich mountingface have been only 1/4" what was actually the main reason why i did continue this.
                EDIT: and if the glue fail, then i will weld the rear barrel solid, so they will be 2pc wheels with greater failmargin.
                what, no eye measurements are used ... rimrings aren't hanging in the air. They are milled in in the centerpiece, even the spokes had to be milled couple millimeters (flush mount? look the pic i drew)
                and has less than 0,2mm tolerance to fit the rimrings in. BBS RS rimrings are manufactured to the same tolerance. It is a snug fit and i had to use rubbermallet to get the rimrings to the bottom. Three of them are perfectly balanced with 5-10g weights and one has 35g and that one has a welded crack on it... actually we managed to do two of these perfectly round and two shows some eccentric wobbling by micrometer, about 0,22mm if i remember right.
                • #23
                  I meant if you had those kind of connections, sorry should have been more clear
                  • #24
                    I had my wheels widened at weldcraft. Amazing work, cool dudes, woot for being local for me.
                    Highly recommend them!
                    • #25
                      dooo it your self:P
