hi im running a 528i (99) on 19 e46 m3 rims al around. fronts are 19X8, and rears r 19X9.5 (stock #s) one of the rims cracked bad so i bought a new rim ( m3) its still 5X120 and 19X9.5 but the inside diameter of the rim ( where da BMW center cap would go ) was off by a few MM. why ? i dont know i thought they all came the same, so i took it to a machine shop and the guy left it just how i had the older rim ( the one that cracked, same diameter and everything), i mounted the rim on no problems, nice and tight no play or looseness. then i drove it around the block and it felt very wobbly in da back.. only after 30mph+. could the rim just need to get balanced? or is it something bigger. also the back tires are 275,35,19. incase its needed..thanx,(very noob ?, but last thing i need is more money dumped into the car
M3 rims feel wobbly??
Check that your wheel was properly bored out by jacking up the car then use something to reference where the edge of the rim is by barely contacting it. Rotate the wheel slowly while looking for any changes in the rim's radius from the center of the hub. It's kind of hard to put in to words but is a simple check that eliminates the possibility of the wheel being bored out off center.sigpic
Just got the wheel back and its all good now ...the tire was bubbled at da side wall people from when I drove it on a flat due to da run being cracked ..but town fair rude replaced it and its fine now ...thanx a whole lot for da interest and attention showed
Originally posted by prod0660 View PostJust got the wheel back and its all good now ...the tire was bubbled at the side wall people from when I drove it on a flat due to the run being cracked ..but town fair rude replaced it and its fine now ...thanks a whole lot for the interest and attention showed
Fixed. Writing the word "the" really isn't too hard.
Instagram@jdjurhuus
