Torque Specs for Fittipaldi 500's?
  • Torque Specs for Fittipaldi 500's?
    Anyone know where I can get the torque specs for my Fittipaldi Modular 500's?
    Like... for the bolts that hold the wheel together? I did 20ft lbs on my friend's OZs.
    2004 350Z Twin Turbo
      i think 20-35 ft/lbs is ok
      id pick a number in the middle and do that
      ig: @jonnie86
        2 piece wheels usually 20-25ft/lbs and 3 piece are usually 30-35ft/lbs. Thats using new bolts or bolts and nuts. If you reuse bolts you cant tighten them as tight. Also do 2 steps. 1st step 1/2 the finishing tq in a star pattern.
        chUD..........Asphalt-sux
        "Success causes envy , jealousy & hatred from the un-successful !!!! "Gregg Valentino
          This.
          On my RSII's I put a drop of Loctite on the bolt, then threaded them all in a star pattern starting at 12ft/lbs. Then I went back around in a star pattern at 24ft/lbs.
            Well you have a lot more patience then me hahaha
              usually in used bolts you can go with 24lbs but depend on the bolts too. For example the bolts that use Gotti wheels only hold 12lbs but the RS bolts holds from 20-30 lbs easily because of the nut
              http://www.flickr.com/photos/wesleygti/
                RSII's only have 16 bolts each so it wasn't that bad.
                  Thanks for the help guys.
                  As of today, the wheels are assembled and awaiting tires.
                  Edited for a little teaser:
                    Fuck yeah!
                      This looks great
                        Holy hawt.
                        Originally posted by da3bous
