Thankyou for the reply! I had seen pictures of that car before and wondered what the specs were. Looks perfect to me.
A close friend of mine works for a local engineering company and says it should be possible to modify the PCD of the hubs. I saw a build thread on here of a 318 compact, the owner went nuts on a 5x114 conversion and adjustable everything, so it can be done I'm guessing.
It's a great opportunity to also knock some studs into the hubs and have male hubs too. Losing the 20mm should make it sit about right I think, I will hopefully be able to have a decent sized tyre setup too.
The fronts are -19 but o disc so a spacer would likely be needed even with a PCD swap. I needed a 5mm spacer to clear standard S14 front brakes.
