Question? Wheel specs
  • Question? Wheel specs
    I drive an s14, and I'm finally buying wheels after having for a few months, my question is will my specs fit WITHOUT major modification like pulling and/or flaring. My friend(also in an s14) is running 17x9.5 +18 with a 35mm spacer up front with roughly 6 degrees of camber, on a 215/40 and 17x10 +18 with no camber in the rear with a 215/45, I'm wanting to run same/very similar specs for the front, so I know they'll work, but my rears are 17x11 +22, Im going to run a 235/40, my question is, how much camber will I roughly need to run these? And does anyone have any photos of similar specs on a stock body s14? Note: I will have the ISIS Performance Pro Series Suspension Arm Package.
    Try them on your friends car...
    Flickr
      Wrong forum....... Silvia.net has plenty of info. With any setup u can image on a s13 or s14
