fuckin sick man!
Did a test fit, ready for air now.
Originally posted by mike410 View PostI figured I'd throw in my two cents as I have these for front struts as well. I decided to slot my top clevis hole, rather than running the cam bolts I was using. I havent had any issues but my car hasn't seen that many miles on it (~1500). I figured if it was good enough for some aftermarket coilover options, that it should be fine on the airlifts.
The guys at Bag Riders assured me that would be a good idea as well, as they have done the same on some of there vehicles. A couple of the guys on the Saturn forum track their cars and advised me to slot the bottom hole instead. If I later decided I needed more, to pick up an aftermarket cam bolt for the top hole.
Originally posted by scweet14 View Postfuckin sick man!
Originally posted by MixDuP View PostSoooo pumped for this man!!
Sent from my iPhone using Tapatalk 2IG: @kyle_eagleton
Originally posted by Kyle_Eagleton View PostThanks for your feedback. How many degrees are you running? And (excuse me, I'm new to this) how did you get your measurements correct when drilling or biasing out the hole so that you had an accurate understanding of what degree of camber it was at? Basically, how can that be measured?
Originally posted by mike410 View PostI'm running -3* at my ride height. I made the hole about twice the bolt diameter in length. I can get to about -5* if I max it out. I don't know if there is an easy way to calculate how far off-center equates to how much camber. I just measured the amount of camber after adjusting it and kept doing so untill I got it where I wanted. A digital level can be used to give you a idea of how much camber you are running.
Struts came in. Received the wrong ones for the rear, but I'm sure Airlift will correct that for me. This stuff is really excellent quality, very happy with my purchases.
Getting a little bit of a stockpile going.
It's personally great to see this come through, easily one of the most satisfying times in my life. To think that I started this process in 2011 trying to find a job that would support a small build with quality parts and coming here is very relieving. Like taking a huge shit.
Also had some clear side markers show up, gonna try them out for a bit with clear fogs as well.
