Need help! Anyone running little camber with some poke?
This topic is closed.
  • #16
    Originally posted by rexxdoggy View Post
    I guess everyone decided to be a little smart. What i meant is, I need help in referencing pictures. But that's okay. Apparently I'm just too lazy to sort through the dozens of pictures with no specs on how much poke with what size tire running at what degree of camber.
    It all depends on what car you have, also this is the showroom which is not for asking questions.
    • #17
      BINGO!!
      Which is why you get smart remarks...
      Instagram @wickedweiss
      • #18
        Even if the question was better formed and in the correct section, most would still make fun of him. Simply because all the information and then some is readily available with some searching and clicking, OP is just being lazy and wants us to spoon feed him.
        • #19
          True. I see your point. I've always just done it using trial and error. Using basic math helps too, and knowing your car's Geometries will help OP. Just saying.
          • #20
            Originally posted by got splits? View Post
            How do you stretch? Do you like heat the rim and pull it with vice grips while its on the car?
            I believe this is the correct way.
            [ame="http://www.youtube.com/watch?v=QLwdWsNDGLg&feature=related"]Bredding av hjulbuer - YouTube[/ame]
            FlickHer
            ^^Click ME!^^
            • #21
              I don't understand
              2005 Mercedes C230
              2000 BMW 323iT
              1998 Toyota Tacoma
              1954 Ford F100
              • #22
                what scares me more then anything is that the op has 123 posts....
                1982 euro porsche 930 turbo
                • #23
                  I think people are missing the specifics of what I'm asking for? I realize I can look at just PICTURES of peoples setups. But hardly any that describe the specifics that I'm asking for. Sure, I can see the actual picture of the setup, of course the wheel specs and more than likely the tire setups. But HARDLY the measurement of poke or the degree of camber. BUT, who's to say that someone with a poke setup is stretching? You're right, there's some people who like the mexi-poke look and run a slight stretch or a squared setup. But maybe with no camber either?
                  You see, the specifics is what I'm asking for, mainly camber degree and measurement of poke, 99% of which the threads I've looked up, don't offer.
                  BUT, that's okay. Because I'm still lazy and even though everyone else's thread should offer that kind of information, I should look my hardest.
                  BECAUSE BROKE STATUS
                  • #24
                    As far as posting in the show room, yes, it probably could've been posted in the wheels and brakes section. Maybe I read too fast, the fact that the show room is a place to "The general style discussion forum, as well as a place to post your car, or any car for that matter."
                    But of course, I just read too fast to realize that requests for any car for any setups would help me to be posted in the showroom was unnacceptable. I guess my perception of a general discussion was wrong, as it should've been more towards a car as a whole, and not the specific wheel setup.
                    My apologies. You guys were right
                    • #25
                      Think if is very diffrent from car to car.
                      Car brand?
                      rear or front?
                      wheel setup?
                      Tire setup?
                      rolled fender?
                      pulled fender?
                      how low?
                      suspension setup?
                      bumpstops?
                      etc etc..
                      inpossible to answer your question.
                      • #26
                        This is true. That's why I asked for reference pictures as stated in my first post. This would help me picture the final product of what I'm looking for. To further clarify, I'll use your suggestions to show a little more information
                        Car brand? Doesn't matter
                        rear or front? Both
                        wheel setup? As long as it pokes 1/2"-3/4"
                        Tire setup? Just has to be flush with fender
                        rolled fender? Yeah
                        pulled fender? Small pull
                        how low? Doesn't have to be super low, just need to see a flush tire setup with some wheel poke
                        suspension setup? Doesn't matter
                        bumpstops? Still doesn't matter
                        For example, let me take the only person I can count on to get the most accurate information possible since he is the same and only car. But can't since I cannot get a hold of him
                        Now, he offers his setup of wheel specs (diameter, width, final offset) as well as tire size. But the measurement of poke, I could probably get a good guestimation of what it would be, but since he has done body modifications more extensive than what I'm looking to do since he runs a much wider setup, it would be harder to match. What about his camber degree? No information. Now I tried contacting him, no response, so I'm on my own when it comes to his setup. These are just things I'm looking for to REFERENCE my imagination on my own. That is what I'm asking. And yes, I do realize that static and air and height all come into play, but once again, I'm using REFERENCING.
                        • #27
                          He probably has a retard filter and it didn't even get to his inbox. Sorry bro looks like you'll have to
                          • #28
                            What the fuck is stopping you from opening a god damn thread and looking at cars?!
                            If you don't care what you're fucking looking at then click through the god damn showroom and look at cars.
                            You went from pretty dumb in your first post, to full retard in your replies.
                            • #29
                              And once again, someone who cared not to see the specifics of what I was asking for. There's a big difference between looking at a picture and knowing the specs of a certain setup. My bad for not making that clear enough in my posts that a picture will tell me nothing without the information to follow up.
                              But you're right, I should just go picture happy and click on all the threads wasting my time on looking at pictures and not finding the information I need.
                              My apologies, once again, for trying to show that I need Information, not just pictures.
                              • #30
                                90% of the threads list their specs. Try fucking reading.
