update fb rx7 build
  • #16
    any updates (read pics) here
    Floccinaucinihilipilification
    • #17
      I own a SA22C (FB in US) but i never think about stanced....
      Right now is with Semislicks Sumitomo R888 and Watanabe RS8 rims but at normal height!
      So..please update your build! maybe i start my own project too....
      1999 Mercedes Benz C43 AMG
      2008 Mercedes Benz G320 CDI
      • #18
        hey sorry this was my original thread but i lost track of it. here is the link to the entire build with more pics.
        more things will be changing this summer.
        no i don't work at jiffy lube. and I found a machined adapter on ebay for the nardi to grant wheel, then i got the grant spline adapter.
        INSTA: @thedrewmclean
        • #19
          Its been a little while since my last update. I picked up some Koni race inserts for the front. they are a much shorter bodied damper than my illuminas i have on the front. Unfortunately the konis are larger in diameter than the strut tubes on the 7. I did a bit of searching and found that mk2 supras use a similar front strut setup as the 7 and the strut tube body is the right inside diameter to fit the konis.
          The front supra struts that i picked up.
          the rx7 illumina damper versus the koni race insert.
          i got bored and decided to make some shotgun pipes for the exhaust.
          I also got some nankang ns2 tires for the front that are a little lower profile so when the front is lowered it will clear the inner fenders. because of the tire size change the front end was lowered half an inch without and suspension adjustments.
          I have started machining the supra struts and i will add some of those pictures soon
          • #20
            Lovin this so far.
            E30 V8 Build thread
            Go here be happy!
            Instagram: stuartrussell
            • #21
              some era wheels could make this look really nice
              • #22
                So it took me about 10 to 12 hours of machining to get the new struts done.
                I cut the supra strut tubes off the supra struts, made some new end caps for the supra tubes on the lathe out of some mild steel. tiged them on the end.
                Then turned the newly capped tube down to make sure it was perfectly round for the press fit into the spindle bottom.
                Bored out the spindle bottom to the size that was needed. Press fit the new tubes into the original Rx7 wheel spindles.
                Here is the difference in tube height.
                Finished product with no paint.
                The new struts give me almost 2" extra suspension travel. so the car will be around an 1" lower in the front.
                • #23
                  Sweet! I'm loving this build.
                  Did you use a race coilover kit from Respeed in the front or a street kit?
                  • #24
                    i love fb's even more than my fc, good job. its not my car so i really cant bitch, just hope deep down you dont rock that roof rack :]
                    IMG_20140729_210811 by MGRAND3, on Flickr
                    My build thread.http://www.stanceworks.com/forums/sh...ad.php?t=33607
                    Instagram: MGRAND3
                    • #25
                      love fb's.
                      keep the rack
                      God bless this mess
                      • #26
                        Arent you going to weld the bottom of those tubes?
                        he mustve enjoyed that bj.
                        • #27
                          It was the respeed race coilover kit. the height adjuster fits soo much better and less sloppy on the supra strut tube now. and i have to drill out the top spring purch to fit over the konis.
                          I don't have the roof rack on it anymore. it makes the car look higher.
                          • #28
                            great work on the front suspension
                            Insta Mintyhinrichs
                            • #29
                              yeah i did weld the bottom. just forgot to mention it
                              • #30
                                I've been looking into an ReSpeed coilover kit for my FB. How do you like yours? You think its worth it to weld in the lower perches on the race front coilovers so you can have a higher spring rate and go a little lower?
                                Do you know how much lower the race kit allows you to go?
