1983 BMW E21 - France
  • #16
    Originally posted by TheNeek View Post
    Details
    yeah, right!
    • #17
      Very cool project, can't wait to see how it turns out.
      My '66 C10 Build
      My BMW 2002 Build
      • #18
        Ok so, from the depths of the threads i come back without good news,
        Shit happens:
        it doesn't seem too bad but all the front end is bent, hopefully not the structure and it still is well driveable but damn fuck, i am so desapointed!
        it happened on the 13th of july.
        i went to some weddings after and i went to hollydays with it and while i checked the fluids for coming back to home i discovered she was blewing the headgasket... it was about the 15th of August... It still starts well but the engine is really not the same now...296 900kms, i can forgive... As i was planing to put in the M10b20 it is not so hard but i did not planed to do that now because i am currently spending all of my time to parting out an Audi 90 for putting the engine in my old passat B2, the Bimmer was supposed to be my DD.
        Long story short, i am putting this:
        in this:
        i began the day after i crashed the bimmer in order to ride the passat as a winter beater and rebuilding the BMW for the next summer... at this point i have to replace the steering, the suspension, the front end, the hood, the front bumper, the right fender, the engine...
        it is a bit more than i expected but it should run great and looks great after...
        in a good note, the center of the PLS are coming back from the shop, modified and powdercoated, i grab them back at Edition 38 in England next week end...
        I will do another build thread about the B2 passat when it will really begun, for now, i just part out the first Audi 90, yes i bought two of them (i will explain that) and the passat is just sitting like the last 5 years or so...
        Nothing great, just wanted to letting you know...
        • #19
          i want!
          • #20
            Nice work... love the coilovers and the PLS wheels
            A pitty people in france use their bumpers to park a car in a spot whats tooooo small...
            AND not look what nice car is behind...
            Currenty owned cars:
            VW passat 3b 1997 daily on 19 inches
            BMW E30 M3 S50B30 waiting for summer 2011
            • #21
              thanks,
              i must admit that was my fault, i anticipate a bit too much what was supposed to do the man in front of me when we arrived to a roundabout and he brakes while i expected he went in...
              Two days later i replace the radiator because he was leaking for months and some weeks later the headgasket blew... i check the radiator before putting it in though...
              I am awaiting my TIG welder in order to redo my coilovers and do the swap in the passat, it is way too long!
              i will pick up a lot of motivation next week end as i go to Edition 38 in UK! Can't wait!
              • #22
                Well, it is time for some updates as i worked a lot on the drive trains of the car lately.
                I was not sure where i as going since i had so much troubles with the coilover conversion, mainly due to some bad parts.
                As the car is the daily and winter is coming ihad to do a lot of maintenance because i do not have funds for a daily driver right now.
                In the last month or so i do:
                -steering rack boots
                -steering ball joints
                -front brake pads
                -full coilover conversion
                -Bilstein B6 from an E30 for the front and rallydesign 8" 300lbs springs
                -Sachs M-Tech from an E30 for the rear with 8" 250lbs springs then 12" 250lbs (8" were way too short for my setup)
                -threaded sleeves welded on the front struts
                -7x15" MIM wheels with 195/50 tires, Goodyear Eagle F1 front and Falken Ziexx ZE912 rear
                for the numbers, it is lowered by 8cms front and 4cms rear for now.
                Pics of the work:
                October 12th
                October 14th
                October 19th
                For reference, the Bilstein next to the stock front shock
                upper cups mods to allow enough clearance for the upper bolt
                the springs are the 8"
                October 23rd
                mod i have to do but that i ***** to! it was way tooooooo low on the rear without that
                modded on the left, without washers on the center and stock on the right...
                adapting the E30 parts to the E21 frame
                And "voila"
                since i had my little accident, the tire was rubbing the bumper so as it is dead, i cut a bit of it
                Then, on the road
                Pretty happy at the moment...
                • #23
                  Buuuuut...
                  Actually the front right strut was a little bent and the bearings i had to use were shots... so i had to do it again!
                  for the story i had to do 2 sets of threaded struts before for the same reason...BAd luck on this project!
                  October 25th
                  the right side, i was sure there was a problem, kinda difficult to show on a picture, but even my girl that is really not into carsor technical things asked me if there were something wrong.
                  Left for reference
                  some measurement
                  Left OK
                  Right Bad...
                  Almost 1cm of difference at the wheel...
                  i ordered another threaded sleeves to weld on my last strut that was originally on the car, i ordered two longer springs for the rear as was at it.
                  November 2nd or so...
                  rear spring swap
                  how close is the spring to the body (i **** the rear setup for a lot of little reasons)
                  November 6th
                  As the strut was bent and the bearing shots, the rotor was grinding the dust cover
                  i spent about 25min to come back to home under heavy rain at nght because my alignment was so bad that the car was almost undriveable, a real nightmare, 25minutes to do something like 5kms...
                  November 7th
                  Ghetto alignment time
                  It was the first time and it was funny. I did it well because the day after i went to an alignment shop and they had almost nothing to do, less than a degree to correct.
                  how it was sorted:
                  and with the last wheels
                  It is where i am at now.
                  Really happy with the handling, not totally happy with the stance for sure.
                  Really unhappy with the rear setup, i might buy some Gaz rear coilovers or do something else with shorter sleeves and Bilstein B6 designed for E21, or some Golf Rallye rear coilovers... don't know yet and unfortunatly i have to work on the motor now as it has a blown head gasket.
                  I have a 2,0L to put in it...
                  After that i will come back to fitment, 5 mm spacers front and 2cms lower, 15mm spacers rear.
                  I also get back from the machine shop and the powdercoating my PLS 3 pieces, i will have to do a test fit as soon as the weather become less bad.
                  Thanks for looking!
                  • #24
                    a photoshoot from this weekend:
                    • #25
                      Very nice build. I like what you have done.
                      • #26
                        Sick project, love old BMW's!
                        1990 Mercedes 300CE- 24 valve
                        • #27
                          great thread, love the shocks work...
                          flickr
                          • #28
                            I feel your pain about the wheel bearings. I have to do another one (found out last night when I got the car in the air). The bearings are sooo small on these cars that you'll eat um up if you don't pre-load them properly. Sucks about the accident coming back to bite you too. Really love the progress. I remember my MiMs, loved those wheels, they really do fit the look of the car.
                            Keep it up.
                            Mr. Belvedere
                            • #29
                              Thanks for the support guys!
                              i had the chance to have another hub with good bearing so finally i just had to swap the hubs but i will replace all the bearings soon i guess...
                              I am very disappointed by the accident too, but it learned me a lot, it was entirely my fault, i was driving a bit too hard with a car not able to do so... at least i learned to do the work well first... on the bette note, i found all i need in the same exact color (Alpinweiss) really not far and for cheap (about 100$), i juste have to pick the parts up and do the massive front end replacement... TIG is on the way and i will have to exercise before doing this work.
                              I hope to do that next summer if my other project is done and good enough to use as a daily driver.
                              I was really not sure about the MIMs but i saw one car on bmwe21.net that suits them well, some minutes later, i found this set on our CL and a friend pick them up in the other side of France, awesome combo and Wheels+tires in the right size for cheap again, perfect for a daily driver!
                              Now, i love those wheels so much for a DD, not sexy enough for show though...
                              I did not know you have a set, Neek and God knows how many times i read your thread on BF.
                              This evening i notice some noise from the right front suspension, i checked all the screws and nuts and all is well tightened, i guess my upper bearing is shot, i did not have the funds to replace them and they have the 298 000kms of the car, i guess the stiffer suspension and our bad roads made them die, another line on the "to-do" list... BMW will love me in a month.
                              I get a new job so i will have some spare money with leaving my current company...
                              I am considering to find some GAZ rear coilover if the can sell only the rear, or find some KW for Golf Rallye, they fit almost perfectly... Perhaps i will go a bit stiffer too.
                              What a novel...
                              Long story short:
                              Thanks for appreciate, it keeps me motivated even more!
                              • #30
                                very nice, one thing i love about white, is almost no damage shows in pics lol
                                nice car man.
