honestly im really impressed with how this came out. had low expectations going in, but im genuinely impressed with how well it kinda goes together with the truck wheels. will definitely be looking forward to the new ones, when the time comes
2010 Dodge Charger Wide body Build
Thanks, These will get me through Winter and Spring. Maybe by then I can afford or a nicer set for Show and keep these as Daily's.Originally posted by scweet14 View Posthonestly im really impressed with how this came out. had low expectations going in, but im genuinely impressed with how well it kinda goes together with the truck wheels. will definitely be looking forward to the new ones, when the time comes
They didn't have a Top 100. Someone told me they did, maybe a long time go they did, but not anymore. Now MOTHERS did an Award and SEMA handed a handful out for certain categories. Mainly booth cars.Originally posted by Josh16v View PostDid you place in the top 100 like you wanted to?!
Just got back yesterday. We have some more work to finished up and a couple things to be fixed and repainted. All simple things. Have to figure out why my HIDs are not working and attach my plastic shields underneath and I can driver it again on the Street. I did do the SEMA Cruise and then took it down LV Blvd. I had to have to loaded back in the Trailer before Dark.2010 Wide Body Dodge Charger
Got the Low Beam HID lights working. Had to get a Relay kit to power them. Now I have to go back and rewire all the Halos, Demon Eyes and HIDs now. Everything is just laying there or taped up with masking tape...lol, Just testing them in the Garage with the lights on. The HIDs don't seem to be as bright as I thought that they would be, but I won't really know tell I get on the road.
So my Current HID set up is.
2x Diode Dynamics Hylux D2 Ballast $160
These are D2-connector 2A88 CANBUS 35 watt HID ballasts, from HYLUXTEK. With true OEM-grade manufacturing, these ballasts are intended to perform for years, with absolutely zero failures. If you have a D2 OEM HID setup with a failed ballast, you can purchase one of these to get back up and running at a fraction of the cost of a new ballast from the dealer. You'll simply need to tap the positive and negative input wires into the power wires powering your original ballast. This ballast should be used with D2 bulbs only (D2S, D2R, D2C, etc). If you have a D1 bulb, or a standard aftermarket AMP HID size such as 9006, H1, or H11, please use our AMP or D1 ballast instead. Most ballasts these days run with digital signal processing (DSP). This allows for a much smoother and more reliable power output, faster warmup, and longer bulb life. However, most digital ballasts still use standardized computing chips to process the information. It is very cost-efficient to use standard chips off the shelf. Instead, the HYLUX uses a computing chip designed specifically for the purpose of running an HID bulb. This is known as an application-specific integrated circuit (ASIC). While this is much more expensive than a generic chip, it allows the HYLUX ballast to operate with extremely high efficiency and performance, far exceeding that of any generic ballast on the market. The ballast is fully sealed in electrically-safe sealant material, known in the industry as potting. It's not just coated like cheaper ballasts, instead, it is filled to the brim, making the ballast completely waterproof and shockproof. The ballast will make a humming noise during operation- most assume this is bad, but actually, it is primarily a result of microscopic air pockets resonating inside, audible proof that the ballast is completely airtight. With the OEM-grade 23kV igniter, which is also fully waterproof, this ballast will strike the bulb perfectly, every single time. It will function in even the coldest of environments, with a rated minimum operating temperature of -40 degrees. This ballast has a CANBUS module, which is designed to provide extra resistance to the vehicle. This is required for operation in many newer vehicles, as they may otherwise shut off power to your headlights, due to the lower power consumption. The CANBUS module also regualtes the power input, to prevent errors with PWM signals. What is that? Well, many newer vehicles use pulse-width-modulation (PWM) to drive headlights, which basically flickers standard halogen bulbs on and off very quickly, to extend bulb life and lower power consumption. It works great for traditional filament bulbs, but HIDs require constant power to run reliably. The CANBUS module smooths the input signal into a constant power supply to the ballast. It has been tested and is effective with PWM signals up to 100hZ, which is within range of PWM systems in most US-market vehicles, such as Dodge, VW, BMW, etc. We recommend using high-quality aftermarket bulbs with this ballast, such as CNLight, or an OEM-grade bulb such as Philips or OSRAM. However, if you have any random, cheap bulb that is in working condition, this ballast will drive it perfectly. Your order includes: 1 HYLUX 2A88 CANBUS HID Ballast with sturdy D2 terminal Diode Dynamics 3-Year Warranty
CNLight D2S HID Bulbs $40
Looking to replace your D2S HID Bulb? Look no further! Available in a variety of color temperatures, these OEM-grade bulbs are built to last!
Morimoto HD Relay Wire Harness $30
Now this was pretty much plug and play all for $230
Pretty much did. Some things I want to change, but overall IMO came out like I was hoping. The Paint job is staying, The Wheels a staying for a bit, Flares will always be bolt on. Never going to change that. The longevity of them, I need them to come off and on easy. I like wide bodies that are full metal work, but they have always looked a little off/odd to me. Specially the fronts. This is basically the LB Wide body for a Challenger that has been modified. last thing the Caliper Covers will leave soon. Working on a Big Brake it. Talking with a couple of Sponsors on that now. If those fall through. Dodge made a BIG brake option mid 2014 BR9 (pursuit) with 14.5in front rotors and 13.8in rear rotors. They are pretty much bolt on it.Originally posted by MikeyRa View PostBetween the paint job, truck wheels, bolt on flares, and stick on brake caliper covers, this doesn't do it for me. It looks like a parts dump in search of someone else's approval.
I hope it came out the way you wanted and you enjoy it.
Thanks, Ya some 4k to 5k wheels do make most cars 100x better looking.Originally posted by brownishwater View PostTurned out way better than I expected.
The paint job isn't really my thing, but to each their own.
I think it will look 100x better with some proper wheels, but still turned out pretty well.
Thanks, Been on many forums and 80% or more of build threads never get finished or are not much of a build then just bolt on stuff. With my current Coilovers and Drive way. I'm low as I can go. My front lip barely kisses my driveway right now. When I get a new coilovers, hopefully front Air Cups... I'm drop it another 1/2in and see how it seats. With my AAD Control Arms I can keep my Camber in check pretty good. This is a Daily too. So have to keep that in mind.Originally posted by xxcody2130xx View PostI dig it man, turned out better than a lot of builds on here. Personally I would like to see it a good bit lower but I think everything needs to be lower haha
Thanks to the SEMA Crunch... I would like get to a new better Hood and I need to fix a couple of spots. But all in all. How fast it went together it came out great.Originally posted by The Simps View PostI like it. Props to you for how quickly it came together too.
Thanks. If my car was any other color from the factory then Black. I would have probably stayed with a solid color. Changing the Color of a car the correct way is so much work. I love all black cars, but all Black would also hide so much of the work done on the frontend. IMO. The Grill and the detail there would have been lost in all the blackness. Maybe I could have changed out all the grill mesh for Aluminum Mesh for a contrast. I may do that next paint job here in a few years.Originally posted by Quillhill36 View PostCar looks well sorted here. Still can't stand the paint, would look better in either color just solid. otherwise, yeah. cool.
I've heard that once before from a buddy. This wide body is made to fit the Stock Bumper not mine. But still doesn't blend in. The front of the front fenders have the same shape as the rear of the rears do. I'm not sure how to blend them in and make them look right thou either. If you have some examples from other WB kits. post em up. I'd love to get more ideas. If it's not to much fiberglass work. I might be able to figure it out.Originally posted by Asshole Bicycle View PostIt'd be nice if the front fender flare blended into the bumper a little better. But it looks dope to me.
Thanks man....Originally posted by saturnstance View PostReally the only thing I'd like to see different would be a different approach to the wide body and wheels. Everything else is good. Kudos.2010 Wide Body Dodge Charger
I feel the pain man, my e36 is my daily, sure is fun though hahaOriginally posted by Ramrod View PostThanks, Been on many forums and 80% or more of build threads never get finished or are not much of a build then just bolt on stuff. With my current Coilovers and Drive way. I'm low as I can go. My front lip barely kisses my driveway right now. When I get a new coilovers, hopefully front Air Cups... I'm drop it another 1/2in and see how it seats. With my AAD Control Arms I can keep my Camber in check pretty good. This is a Daily too. So have to keep that in mind.grimegang_cody on insta if you want to follow my build
Oh I love being low, but it is a pain in the ass sometimes.Originally posted by xxcody2130xx View PostI feel the pain man, my e36 is my daily, sure is fun though haha
Here is my Driveway. My new bumper hangs 1in lower then this. My Ez-Lip drags going in everytime. Not sure how long it will last doing that..lol
Originally posted by Ramrod View PostOh I love being low, but it is a pain in the ass sometimes.
Lip will last way longer than you think.
I'm sure cody gets this too but my suspension components will bounce off of the road on bumps and scrape nearly flat ground if the spot is crowned bad enough. That's when you gotta start worrying. rubber/plastic will be fine for a while. Honestly, I think a full spray in that blue would be nice. never seen it on a charger before.2 328i e36's
Saabaru linear 2.5na
Various projects.
Intro;
http://www.stanceworks.com/forums/sh...19#post1598619
The Blue is B5 Blue. It was a 2008 Dodge Color and was brought back in 2015.Originally posted by Quillhill36 View PostLip will last way longer than you think.
Thanks, Doesn't bother me much at all. I've looked up some of the ****** builds and their rides and it just makes me laugh.Originally posted by becausephilchow View PostI gotta say, I really applaud your attitude. Even though what you did to your car is not for me, and everybody is telling you that it didn't turn out well, you seem to take the criticism really well. Props to you man!2010 Wide Body Dodge Charger
I've seen it on a few challengers but not a charger. that would look great.Originally posted by Ramrod View PostThe Blue is B5 Blue. It was a 2008 Dodge Color and was brought back in 2015.
2 328i e36's
Various projects.
Intro;
Almost have this back on the road again. Been dicking with these HIDs for to long. Got them working, but odd things with my interior dimmer switch is happening. Going to order one more Anti-Flicker harness and see if that fixes everything. RetroSource thinks it will. Next Time I'm going all LED. If Diode Dynamics wouldn't have Sponsored me for the HID and Bulbs. I'm not sure if I'd make switch.2010 Wide Body Dodge Charger
