Nice progress. Big fan of the wheels. Actually looked at these for my E39, but wanted a staggered setup. They really suit the your E46 though. think I'll be following this thread!
E46 Daydreams
I was using sealeant, but without success. Not sure, but maybe crankcase ventilation does not work as it should, makes pressure under rocker cover which makes oil leak. Should check before oil change.Originally posted by Fruttolo View PostEver tried coating the gaskets with sealant paste? I had a friggin leak in my golf that did not want to go away because of a ruined o-ring seat, so I gobbled a bunch of grey sealant on it, torqued it down and voila no more leak. Not the "right" way to do it but I **** leaky cars so extreme problems need extreme solutions
It's right to use a thin layer of sealant over gaskets.Instagram valgers97
This is definitely a good shout. Too much pressure can sometimes blow the gasket, which is what happened on my M52, changed all the crankcase breather pipes and breather, problem solved!Originally posted by RV97 View PostI was using sealeant, but without success. Not sure, but maybe crankcase ventilation does not work as it should, makes pressure under rocker cover which makes oil leak. Should check before oil change.
Hi everyone,
Car currently looks the same as it did.
I did take care of a couple of things. Firstly, I used a paint correction kit to paint in the number plate trim scratches, so now I don't have two random white dots on my plate. I did the same to the two golf sized chips just underneath. All in all, good stuff.
I also bought some £2 shiny nut covers. On one hand I now feel like I'm driving a Chrysler 300C but on the other hand I'm happy that I no longer have miss matched wheel nut colours. It'll do until I have spare cash for proper bolts.
I also made a new pal on instagram who has a lovely E36. His name is Aidan and some of you have probably seen him on the gram.
He has made me realise two things. 1, I want an E36 vert, and 2, my stance game is weak. Looking at my rake now makes me want to cry and I'd very much like to drop the rear so it's sitting level and ideally I'm tucking tire.
I stuffed some pals into the back of my car and I absolutely loved the way it sat.
Unfortunately for me, I cant drop the back anymore, meaning I'm either going to have to get some scissors out and do some choppy bits, or find some new springs. I'm worried however that if I get new shorter springs I'll end up busting the FK AK dampers. Which would be unfortunate.
Anyone got any tips/ideas? I don't fancy spending on £800 worth of new coil overs just yet, before someone at the back suggests it.
Thanks. Yeah, I've kind of gone off it.Originally posted by dres2x View PostNice job guy
I really like the KBS styling side skirt extensions. A little less the front splitter.
Thanks, I took em off for my MOT and haven't bothered since. They're cool but they're a lot of hassle and don't really fit the OEM+ theme I've got going on. Might save it for when (if) I get splits and do some jap themed stuff. Just an idea for now though.Originally posted by 19birel View PostThose striped tail lights actually look pretty sweet with the clear indicators
Glad you were able to take care of the maintenance without too much issue, always feels great to have the car running tip top.
Hmm, on one hand it's nice to know I'm not the only one with this problem but it's also a shame this problem exists. Thanks for the plug by the way!Originally posted by RV97 View PostI think oil leakage from rocker cover and oil filter housing is very common problem for older BMW's. I have changed mine many times with no success, sadly. It keeps leaking anyway, but less.
BTW you can look at realoem.com and find all parts, pricing and part codes for BMW's.
Thanks! I don't think they'd fit onto an E39 anyway as your centre bore is too t h i c c.Originally posted by thirtynine View PostNice progress. Big fan of the wheels. Actually looked at these for my E39, but wanted a staggered setup. They really suit the your E46 though. think I'll be following this thread!
Sounds complicated. I'll go to the pub instead.Originally posted by RV97 View PostI was using sealeant, but without success. Not sure, but maybe crankcase ventilation does not work as it should, makes pressure under rocker cover which makes oil leak. Should check before oil change.
Drive it till the wheels fall off I say!Originally posted by Minuki View PostThis is definitely a good shout. Too much pressure can sometimes blow the gasket, which is what happened on my M52, changed all the crankcase breather pipes and breather, problem solved!
Thanks. I think you look great too.Originally posted by becausephilchow View PostI think your car looks great as is, and doesn't need a front lip.Last edited by Mehowski; 04-18-2018, 06:16 PM.
You are probably going to bust the dampers as it is now, coilover kits aren't designed to run "all the way down" as we use them so if I were you I'd not be worried. Did you already remove all spring collars in the back? They free a fair amount of lows when removed.
Be aware if you tuck tyre you may need heavier rate springs or you are going to chew your tyre in your wheel arch, there is not much room up there.
Btw I like your current stance, very balanced and oem looking, to me there's no need to lower the rear a lot
FB: @DumbassCarCrew - IG: @fruttolo_dumbasscrew
Could try a set of these if you go with shorter springs to keep the shocks happy.
Garagistic is your trusted source for high-quality BMW performance parts, specializing in E30, E36, E46, and more. Discover custom-engineered components, from suspension upgrades to drivetrain solutions, designed to enhance your BMW's performance. Shop now for fast shipping, expert support, and unparalleled quality.My super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
The front end is still screaming for a set of projectors IMO. You can retrofit projectors in a set of reflector housings pretty cheap with good results, would even give you the chance to add halos if you wanted.
RIP
"Effy" E60 BMW 530xi 6MT [N52] Build Thread
+1Originally posted by Fruttolo View PostYou are probably going to bust the dampers as it is now, coilover kits aren't designed to run "all the way down" as we use them so if I were you I'd not be worried. Did you already remove all spring collars in the back? They free a fair amount of lows when removed.
I liked like this, focus on a swap maybe
Aidan's BMW looks cool but the Miata looks even better!Last edited by DawsonLiri; 04-28-2018, 09:17 AM.
Hi all!
Car is broken again - not ideal.
Coolant expansion tank has given in and is leaking from the joint at the top. New one is £35 which isn't bad, then £20 for new coolant and then I have the fun job of bleeding that. Luckily for me the engine didn't overheat!
Bit annoyed, was hoping to take it to a car meet on Sunday but now I have the whole summer of using it to look forward to knowing the cooling system might become temperamental again.
I'm going to get this fixed then I'm tempted to get rid of the car - it's been giving me shit and I feel like it's reaching the age where everything will need repairing soon.
Currently tempted to buy another small run around like another 6n2 and just use that whilst I save up until I'm 21 in January and treat myself to something cool again.
Keen to hear opinions, but I'm bored of the thing breaking and I want to save money.
thanks!
Michal
Projectors would be cool. Or I could credit card my way into another E46 which already has projectors. And is black. And has a sunroof. And cream leather.Originally posted by 19birel View PostThe front end is still screaming for a set of projectors IMO. You can retrofit projectors in a set of reflector housings pretty cheap with good results, would even give you the chance to add halos if you wanted.
If I get an exhaust I'll start mistaking the car for a Corsa. Nothing wrong with Corsas, but I don't want one.Originally posted by Tris_xkr View PostI rekon you should get some gloss black grills, and a new exhaust. The exhaust will definitely make you want to keep it and do more trust. I had them change the exhaust on the jag before i picked it up lol
might be a planOriginally posted by hinrichs View PostCould try a set of these if you go with shorter springs to keep the shocks happy.
https://store.garagistic.com/Garagis...nt-E30-E36-E46
On my way!Originally posted by Benwalsh91 View Posthaha I have 20x polished bolts at home from my 36. swing by if you want them.
thanks, shame my car doesn't like itself and keeps trying to commit suicideOriginally posted by Fruttolo View PostYou are probably going to bust the dampers as it is now, coilover kits aren't designed to run "all the way down" as we use them so if I were you I'd not be worried. Did you already remove all spring collars in the back? They free a fair amount of lows when removed.
Btw I like your current stance, very balanced and oem looking, to me there's no need to lower the rear a lotLast edited by Mehowski; 04-28-2018, 04:17 PM.
Hi!
Fixed the coolant expansion tank - chucked a new air fliter and everything seems good.
Service coming up soon too! Already bought the bits for it. I've also got new center caps coming (hopefully tomorrow) and front spacers at the start of next month all in time for Players Classic.
Anyway, decided to add some pin stripes. What do we think?
Looks pretty cool imo! I'll be keeping them.
I'll make my white tail lights again before Players Classic too.
The American number plate is off atm as the glue was coming off the frame and I don't want to lose it.
Hope you've all been well guys!Last edited by Mehowski; 05-18-2018, 03:50 PM.
