Dang thats fking awesome!
Euro Spec Kouki Silvia
Thank you!Originally posted by SoapHero View PostDang thats fking awesome!
Finally got around to mounting the OZ futura's, new gold hardware and 4 new lips in 3'' this time, squared setup of 17x10
IMG_20180530_200119 by Nikolai Solbakken, on Flickr
IMG_20180609_173951 by Nikolai Solbakken, on Flickr
mounted 4 new tires as well as an alignment so now the car is back to a rolling project, using the s14 as a daily now so the rugged s13 (red one) can get some much needed tlc.
IMG_20180611_220853 by Nikolai Solbakken, on Flickr
IMG_20180611_221118 by Nikolai Solbakken, on Flickr
IMG_20180611_221301 by Nikolai Solbakken, on Flickr
IMG_20180612_231140 by Nikolai Solbakken, on Flickr
And a few of the underside.
IMG_20180613_154924 by Nikolai Solbakken, on Flickr
IMG_20180613_154954 by Nikolai Solbakken, on Flickr
IMG_20180613_154948 by Nikolai Solbakken, on Flickr
Will update you guys while moving forward with the the S-chassis cars, probably with some time between each update so I can pack some more information and work into each one
CheersIG @Hansolbakken
Back at it again, this summer I've been really busy with life and stuff so the projects have more or less been neglected.
However I'va managed to put in some work, the red s13 had an issue with oil leaking from pretty much everywhere imaginable.
IMG_20180615_204924 by Nikolai Solbakken, on Flickr
IMG_20180615_205011 by Nikolai Solbakken, on Flickr
IMG_20180616_022942 by Nikolai Solbakken, on Flickr
IMG_20180616_022951 by Nikolai Solbakken, on Flickr
So rebuilt it with new gaskets and a new oil pump,crank gear, water pump and all belts.
IMG_20180716_195027 by Nikolai Solbakken, on Flickr
IMG_20180829_200153 by Nikolai Solbakken, on Flickr
IMG_20180829_200206 by Nikolai Solbakken, on Flickr
IMG_20180829_200245 by Nikolai Solbakken, on Flickr
just started last week removing and fixing some of the rust on the red s13, and as if owning 3 S chassis cars doesnt keep me occupied..
I bought a new S14 Kouki, its the so called Racing Edition so only offered in Cobalt Green Pearl, has a beige leather interior and Z editon rear lip. Around 800 of these where made by Nissan Germany.
IMG_20180830_185216 by Nikolai Solbakken, on Flickr
IMG_20180831_204632 by Nikolai Solbakken, on Flickr
IMG_20180831_122025 by Nikolai Solbakken, on Flickr
As the season here in the north is coming to an end, you can expect more frequent updates as the cars will be stored/upgraded during winter.IG @Hansolbakken
Thank you! Not much use in doing something halfway.Originally posted by Scrape Much? View PostSo satisfying to see somebody do everything so thorough, big ups to you! Beautiful car
just a small update for you.
Buying a high mileage 28 year old S13 that's seen its share of abuse and norwegian winters comes with some problems.
The major one being rust and more rust!
So as you can tell from the pictures, this is one of those cars. I'll try to do my best in fixing this but I'm by no means an experienced welder.
This week I've started cutting out the old rust, then I ordered some new sills from the UK that's on the way.
The fix for this will probably be quick and effective, not the prettiest but for this old drift sl*t. Fibreglass fenders and bumpers will be the solution.
I'll update this when I've got more to show for. on to the pictures.
IMG_20180915_204245 by Nikolai Solbakken, on Flickr
Fuel tank is gone, has a neat fix with nitril gloves and insulation tape. new one on the way.
IMG_20180915_224638 by Nikolai Solbakken, on Flickr
IMG_20180915_224653 by Nikolai Solbakken, on Flickr
IMG_20180915_224708 by Nikolai Solbakken, on Flickr
IMG_20180915_224721 by Nikolai Solbakken, on Flickr
IMG_20180915_224736 by Nikolai Solbakken, on Flickr
IMG_20180915_224758 by Nikolai Solbakken, on Flickr
IMG_20180916_202923 by Nikolai Solbakken, on Flickr
IMG_20180916_202944 by Nikolai Solbakken, on Flickr
IMG_20180916_210404 by Nikolai Solbakken, on Flickr
IMG_20180916_203010 by Nikolai Solbakken, on Flickr
IG @Hansolbakken
Thanks man, Almost afraid to use the car when it's this clean underneath.Originally posted by kevvy_dawg View PostKudos to you man, that's a beaut. That gold/black combo on the underside is perfect IMO.
Hope you like corrosion because that's all I got for you in this update.
I realise a more reasonable man would have parted out the car by now. But where is the fun in that?
This is all I've found so far, cutting out the rust is coming to an end so soon I can get started on welding and painting the car. more on this later.
driver side
IMG_20181016_204138 by Nikolai Solbakken, on Flickr
passenger side
IMG_20181016_191241 by Nikolai Solbakken, on Flickr
IMG_20181016_191215 by Nikolai Solbakken, on Flickr
IMG_20181016_191227 by Nikolai Solbakken, on Flickr
IMG_20181006_010023 by Nikolai Solbakken, on Flickr
IMG_20181006_004220 by Nikolai Solbakken, on Flickr
IMG_20181006_004235 by Nikolai Solbakken, on Flickr
IMG_20181006_004212 by Nikolai Solbakken, on Flickr
some piles
IMG_20181006_004201 by Nikolai Solbakken, on Flickr
IMG_20181016_191205 by Nikolai Solbakken, on Flickr
IMG_20180925_203444 by Nikolai Solbakken, on Flickr
and the new sills
IMG_20180925_203521 by Nikolai Solbakken, on Flickr
To summarise : gotta love old s-chassisIG @Hansolbakken
