This car looks so good in person.
One bad V12 - 1998 E38 750iL
BATTLESTATIONS
Rear coils are installed. Fought the stock ones something fierce to get them out, not the lower bolt (which is usually rusted on), just wrangling them through the suspension arms. This is about as low as the coils should run at the rear, any lower and the springs are slack under droop and you're lower than the recommended minimum height. I have a bit of rubbing on the driver's rear fender, needs a little roll. I may raise the rear up a bit anyway.
It rides surprisingly good. It's funny, with only the front coils on, it was still choppy and bouncy, turns out, as I'd thought, that was just due to the worn rear shocks. Even this low it feels great so far. Still firm and sporty (I'd wager stiffer than the OEM sport suspension) but not harsh and not riding on the bumpstops.
Patented (not really) Aitch method for pulling fenders. Jack up, insert thick stack of cardboard, lower gently.
Result
Now that looks good.
Damn. Nice e38 man!Lucas
Wrap is nearly done. Will try to do some real photos this weekend to show the actual color.
Until then:
SitRep: Exterior vinyl is done. Interior vinyl is mostly done. Headlights now have aftermarket bixenon projectors in both the high and low beam housings, because the passenger OEM low beam housing had also lost it's reflective surface. So I just went full aftermarket. I still need to adjust the beams a little bit. I also added the front bumper splitters from eBay.
Also had to replace my radiator (which sprung a leak), drive belts, and top radiator hose (which was slightly too big and rubbing on the fan when it got hot and expanded).
The exterior vinyl is Gloss Midnight Blue from Arlon, which was discontinued this year so I got it at a killer price. Close up there are a few areas that aren't perfect, but considering I didn't pay a shop $2-4000 I'm more than satisfied.
I took these photos in the same spot as my first ones, so you can see the before and after.
Ah this is cool as!!! I'm looking forward to seeing the interior when you modernise the woodgrain, don't think I've seen a v12 7 series before bet it's thirsty right?LIL HIGH x LIL LOW
My stage 3 Focus ST MK2 build:
http://www.stanceworks.com/forums/sh...CON-1-Focus-ST
Wow!!! Wait, has the car always been blue??? I could have swore it was black lol stunning big bus...My BMW E36 318ti Steel Blue Compact build thread -
Thanks! The last photo shows the new vinyl woodgrain on the interior. I didn't do any other interior shots as it was dirty and the shift boot was torn. I get ~15mpg in daily driving, can get 20-22mpg on the highway.Originally posted by Fudge View PostAh this is cool as!!! I'm looking forward to seeing the interior when you modernise the woodgrain, don't think I've seen a v12 7 series before bet it's thirsty right?
You're not wrong, at the start of the thread you can see it was black. This is blue vinyl.Originally posted by Steven_318ti View PostWow!!! Wait, has the car always been blue??? I could have swore it was black lol stunning big bus...
