LS1 Drift Build 'Nuff Said'
  • Damn, very impressive work. Interested to see how this thing turns out.
    Originally posted by Kyle_Eagleton
    Come to America. We have no rules. And plenty of fast food.
    • A lil update on whats going on.. I should have full update come this weekend so look out for some good beer and even more sick build pics.. Got a lot to show you guys..
      • i know i said it before but i love your build, hopefully i can do something almost as nice with my fd after i finish up with school
        • Sub'd, I'm in love with this car, and the interior is incredible!
          • NICE, last few pages I've been yelling in my head "please dont let this thread end before wheels and tires are mounted up." SOB
            sick build
            l ig:coltondk l youtube:coltondk I DD: Tundra I Projects:l 06 STI I 87 S10 l I 57 Chevy Belair I I 48' International KB-2 I 07R6r l
            • Thanks guys for the kind words..
              Oh this thread will never end. There are a lot of things I plan on doing to the car later on so look out for more updates once car is started and running..
              But look out for this Sunday for a big update of what has happen to the car and whats to come
              • Okay finally a good update, been kind of crazy over here with the move to the new house and ordering a lot of fittings and hoses. But here we are so lets get this party started.
                Lets start this off with a good beer. Since I have put beer a side for a couple of months (I know I'm crazy right) to get my body back into shape. Going to post up some picks from my good friend Drew. he has a Instagram posting nothing but the best crafted beers so check it out.
                I begin this update with a little trip to Houston to pick up my built T56 tranny. Got all the good ready for the trip for me and the lil man.
                I acquired the transmission from my good friend Evan. He owns D3 Performance Engineering and they do so sick work.. Only the best, they were the ones that tuned the Hennessy lotus. So needless to say they will be the ones that tune my car.
                I also purchased some goodies for the T56. Monster Clutch was a no brainier and they were well helpful when deciding which clutch to go with.
                I went with there 11" clutch with pressure plate and light weight flywheel package.
                Love the level of detail; just in making sure the customer package includes everything.
                Also picked up my Saiko Michi Dual Catch can..
                Love the look of this thing
                Okay lets start some installs.. I picked up a new Slave Cylinder. and a backup you never know.
                But first I have to switch out the lines for my Chase Bays lines..
                yup undo this....
                removed
                new bleeder line about to get installed
                I think thats about right
                Tighten that **** up with some 15mm
                Next is the clutch line itself
                have to removed this, but what there is no screw
                You have to knock out this pin
                yup
                Once the pin is knocked out the fitting should just pop off
                view of the pin
                Install the new line and insert the pin.. Hammer that sucker in..
                BAM!! looks like money
                Time to install
                You know me only the best.. ARP bolts...
                Next on the list is to remove this shifter level for a GTO one.
                This can show you the difference in size between the two.
                Look came to help out dad.. Thanks bud
                Again this has a pin that you have to remove and reinstall
                Now I could install my Sikky shifter
                Also drilled and tapped for my bleeder line.. Installed and ready to rock
                So removed the engine to start on the T56 install
                Start out by removing the old pilot bearing.. I rented this blind puller to get the job done..
                Let's do work.. Took me about 2 min to remove.
                Out
                View of the old vs New..
                tap that sucker back in..
                installed
                Flywheel going on.. Again ARP bolts are needed
                Clutch and pressure plate getting installed.. The green monster
                I also re-taped some of the holes on the engine so the bolt holes would not striped. I used Hilico to get the job done.
                Back in you go.. And yes I removed the shifter
                • Next I had to tackle the fuel setup. Went with Aeromotive 340 pump and also hit up CJM for their OEM Pump To -6AN and Return Fuel Correction Kit..
                  Took out the old fuel pump unit
                  Take it apart
                  Pop this bottom cap off that holds the fuel pump in..
                  Remove the sensor
                  Out!!
                  Side by side view
                  Place rubber cap
                  Install the filter bag (I think that is the name oh well)
                  Place back in
                  You have to shave done some of the cap to make it fit.
                  Drill this sucker, if not you will have a rough idle..
                  Pop back in
                  Time to install the return line.. Drill whole
                  install fitting
                  Another view from underneath
                  install this guy and make sure all the seals are in place
                  Install line to it
                  Run the line to the top
                  Next install the OEM Pump To -6AN..
                  Complete!! Now just place back in the car
                  So painted my Coolant tank
                  And reinstalled.. I think it looks 10times better
                  Also while the engine was out I installed my new fittings for my power steering rack
                  Also started to install my Fuel Pump Regulator
                  • Installed
                    Also installed my bulkhead for my oil line to my Accusump
                    View of all of them installed
                    Also started getting my fittings and lines in.. This is what the color scheme is going to look like.. Keep it classy
                    I also picked up a new steering wheel.. Only gloves are going to touch this thing
                    Time to install the catch can since the motor is back in..
                    Bracket installed
                    nice and clean..
                    This is how I will route the catch can
                    I picked up these sick locking bolts for my headers so they will not leak on me.
                    Now here is a pic of them installed BUT... this one I took a pick of had to be fixed,, as you can see it would not be doing any thing if it was not at the 11 position. But I liked this pick so posting it.....lol
                    While I was waiting on hoses and fittings. George sent me the kit we have been working on for the dual caliper setup. This thing is top notch..
                    Bracket bolts to your hub and actually pushes your wheel out another 4mm. So def have to take note of that when getting my 18s for drifting.
                    Everything is included
                    So these are going to go into production soon but George sent out a small batch to some people for testing. Once that is all said and done he will start selling them like he does the S13/S14 brackets on zilvia
                    So for now I will only be using the OEM iron calipers.. Still bouncing around which calipers I want to run.
                    Hub removed
                    Sorry to say but you will loose the OEM e-brake with this setup. But he is working on another kit to keep it. But for me BecauseRaceCar...lol
                    install bracket
                    BAM installed and ready to rock..
                    So while I was still waiting for some parts.. Lets mount some tires
                    Wheel specs are 19x11 0 19x13-20.. Now these are not my drifting wheels just marketing wheels.. So might be selling them after photo shoot.
                    Feel sorry for him..lol
                    11s were easy
                    Cheetah time
                    POW!!! mounting 275/35 on the 13s
                    11 stretched on 245/35
                    13s looking damn good
                    Perfect stretch
                    Back home and looking good
                    test fit. Over fenders are replacing the OEM ones so it will sit nicely..
                    Another view
                    Got my Fan shroud from Blake (the one with the sick FC build) thanks buddy..
                    Painted it crinkle black and mounted my fans
                    Mounted up
                    Looking good..
                    Picked up some tools for the AN fest we are about to get in to..
                    Also picked up this to make install easier
                    Got hoses?
                    fittings laid out and all labeled so I know what goes where.. Lets do this
                    Install begins..
                    Good thing I have these
                    Looking good.. Now lets run fuel lines
                    I ran them were the old fuel lines went. But thinking about putting a plate over them so nothing hits them.. Thought?
                    Fuel setup complete
                    Bottom Radiator hose
                    My front coolant lines
                    They Tee off right here and head to the coolant tank
                    The driver rear coolant line
                    Passenger coolant line and some of the fuel lines
                    Oh yeah all hooked up
                    My Dual Catch can lines ran
                    Found these sick fittings that match my AN ones perfectly
                    Another pic of the lines ran to the expansion tank
                    Line ran from the Radiator to the Coolant tank
                    Big Ass Radiator lines
                    Mounted my oil filter in the back near the brakes.. Clean and out of the way
                    A full pic off everything ran.. Looking good I must say
                    All of it is coming together
                    I also mounted up my Status Racing seat to check the fit.. Looks good
                    This view is so sick.. Next is to install my Carbon Fiber door panels and floor boards... Should look sick when done
                    God I can't wait to rip on you.. oh yes
                    I also got some goods for out side the car..
                    Love this hood. went with the 07 cause I love that hump. I will color match this hood and leave the vents CF..
                    I also have this Coming in the mail TS diffuser and some new side skirts..
                    So that is it for now.. I should be getting some stuff in the mail and the next phase is exhaust so should be heading out that way in a couple of weeks..
                    Also I will post amount later.. Thanks guys
                    • Now that's a solid update.
                      This thing is gonna be nuts.
                      The Kia has been parted.
                      • Killin it bro!!!! appreciate the shoutout! cant wait till our cars are dialed in and ripping
                        Instagram: @B_OLSEN_
                        1988 FC3s-LS3 track slut~in progress~
                        1991 S13 Coupe-LS1 street beater
                        2004 G35 Coupe track model-Work Wheels Static daily
                        TUMBLR
                        • How do you feel about the rear radiator cooling setups? I think this car could have one, I think I even have a design for it! What do you think? Anyway, AWESOME.
                          • Love the fish eye interior view, I would love todo this to mine!
                            • oh man, this is gunna be a serious tyre slayer! Hope it all runs smoothly and you dont have any major problems in the end, would **** to see this plagued by constant issues
                              • suck a solid update, im so jelly atm.
