May I ask what lip were You running on bumper? I'm getting tired of golf mk3 lip on my 190
Static 190E 2.3-16
Assuming that you are speaking of this lip -Originally posted by Fila View PostMay I ask what lip were You running on bumper? I'm getting tired of golf mk3 lip on my 190
It is actually the bottom of an old w126 bumper cover - turned upside down, and then cut out as you see you see it here.
Finally had a chance to finish filming a project I started in summer. It shows some of the evolution of the car. Hope y'all enjoy it as much as I enjoyed making it!
Yes, this is static.Last edited by Deutschland201; 12-02-2017, 07:18 PM.
Thanks for the compliment.Originally posted by Fila View PostLove the ride height
What are you running for suspension in the front?
Running Bilstein B8 Performance Strut in front (P/N 22-003652) coupled with the strut mounts from a 1995 500SL (aka w129 chassis) which are P/N 1243200473. The SL strut mounts give you about 3 inches more travel than the typical w201 strut mounts.
Springs are from a w124 wagon and cut to desired height.
Is there enough hood clearance with sl top mounts?Originally posted by Deutschland201 View PostThanks for the compliment.
Well, there is enough that the shock does not poke through the hood. But, the clearance did not come without a bit of shaving. You will see that I had to grind down the edge of the shock and the retaining nut.
DSCN4729 by Ian Rose, on Flickr
And, as you can see, there is some scraping on hard bumps.
DSCN4730 by Ian Rose, on Flickr
But, I have not dented the hood. So, we're still good.
DSCN4731 by Ian Rose, on Flickr
And, just for fun, a picture after installing the LED foglights.
DSCN4732 by Ian Rose, on Flickr
Here is a video that I shot primarily to address the w202 chassis Mercedes. HOWEVER, because w202 springs are often used on w201 (190E) and w124 (300E, 500E, etc.) chassis Mercedes, I felt that it would be worthwhile to share it here too. Within the first 2 minutes, you can get all of the information you need from the video.
