New wheels look perfect.
Slowest 190e build ever
Wow, wheels looks great!
I don't know how much stretch you're searching, but this is 195/45 on 7.5 wheelOriginally posted by Fila View PostAlso does anyone know will 195/45 stretch just a little bit on 7.5 or it won´t stretch at all?
But with your ride height are gonna looks amazing
If not 195/40 are the one
But you're gonna need more low
Well I don't want to run 40 profile tyre so 45 profile needs to do it. If it will rub in the back ill probably somehow adjust the height so it doesn't lol. Thanks for info and pictures
No problem man.Originally posted by Fila View PostWell I don't want to run 40 profile tyre so 45 profile needs to do it. If it will rub in the back ill probably somehow adjust the height so it doesn't lol. Thanks for info and pictures
If you don't want to run /40 but you want some stretch you can try some 175/50 maybe.
Can't run anything narrower than 195 legally here and I prefer little bit of a meat so if it will rub on 195 I'll adjust stance according to that. Thanks anyway
Camber makes anything work.2 328i e36's
Saabaru linear 2.5na
Various projects.
Intro;
http://www.stanceworks.com/forums/sh...19#post1598619
So few days ago I finally took my time and cleaned the wheels completely and wetsanded all the light scratches but forgot to take any pictures.
But really exciting news is that I found really cheap tires in the right size and exactly the same brand which I wanted to buy so tires are mounted and wheels are on the car.Also they stretched just how I needed and wanted them to do.
I was hoping for a little bit more poking rear fitment but this is fine and I did not have to roll the fenders. Fronts need to go lower and need 10mm spacer so I ordered spacers so expect it lower in the front very soon.
Also this is the height in the back without anyone in the car
Friend of mine took few quick photos of me rolling on new wheels
After seeing this photos I think I'll go with 30mm spacer in the back for wider stance
New Update
Car was lowered upfront(1 coil cut)
After that my front spacers finally came. Installed them was absolutely stoked on the fitment but as soon as I turned the wheel I was disappointed. It was rubbing heavily so I tried rolling fenders but it almost did not help at all because my tire has big sidewall without stretch.
To solve that problem I had 3 choices:
1.Raise the car and keep the spacers (no way)
2.Keep it at the same height and lose the spacers = sunken in fitment
3.Keep it at this height, keep the spacers but add camber
You can be sure I have chosen option number 3. Now I don't rub, I am still kind of low upfront and have matching camber front and rear
DDD but only minus is that I still have kind of sunken in fitment upfront(gotta learn to live with it for a while).
Anyway here are some fresh photos of the car
Gotta say that underside definitely felt that offroading as I was scraping all the way to the spot
And here is new side profile shot with new height
Hope You guys like new update and pictures and look foward to new updates in the future
