I have a 1992 190e 2.6. I recently bought coil overs made for an e36 that are pretty much bolt on for my car. When I first installed them I was able to get them fitted to my top mounts but it wasn't exactly perfect. Also where I didnt cut the front springs, it wasnt allowing the coil springs to compress because the were too long. The coil spring is actually 2 springs seated on top of each other which makes a lot of noise. Any ideas on new coil springs that I can fit to the coilovers that I have? Also the height adjustment rings rubbed the tires pretty bad, would adjustable camber plates give me clearance behind the tire? I was told you can use mr2 camber plates but they need to be cut/altered
