Time for some tunes
So i pulled the passenger foot kick panel and cut the CD changer connector, and after thinking about how I wanted to route the radio shack connector, I sat down at the kitchen table and soldered wires to the 5 pins using bits of my old GM truck harness from my swap. small scale soldering is not my strong point but I got it done.
I made temporary connections to everything (left the bare shield wires disconnected from anything), stuck a CD in the changer, crossed my fingers, reconnected the battery, and let her rip
_DSC4771 by Norbert Ogiba, on Flickr
SUCCESS! Using a 3.5mm to 3.5mm I was able to get my phone to play music and it sounded great. Figured I'd take it one step further, and plugged in my Miccus Mini Bluetooth adapter, which is a tiny portable unit that takes a bluetooth audio signal (like from your smartphone) and converts it to audio output through a 3.5mm jack. After making sure it was paired properly, that worked perfectly as well! So now I have wireless bluetooth AUX audio through my smartphone, which will be great this summer on those long road trips. Sure beats those expensive AUX converter units
Now I need to clean up this mess, solder and heatshrink everything, and run the aux port into the center cubby where the bluetooth module will be housed.
_DSC4773 by Norbert Ogiba, on Flickr
_DSC4771 by Norbert Ogiba, on FlickrSUCCESS! Using a 3.5mm to 3.5mm I was able to get my phone to play music and it sounded great. Figured I'd take it one step further, and plugged in my Miccus Mini Bluetooth adapter, which is a tiny portable unit that takes a bluetooth audio signal (like from your smartphone) and converts it to audio output through a 3.5mm jack. After making sure it was paired properly, that worked perfectly as well! So now I have wireless bluetooth AUX audio through my smartphone, which will be great this summer on those long road trips. Sure beats those expensive AUX converter units
