Started my annual winter project of "take a perfectly good running vehicle and take it apart"
Midpipes and exhaust removed. Now on to 36 of these little bastards. Thank god for power tools. Stiffening plate was not as stiff as I imagined it would be.
Begin the parts pile.
No pictures of the physical removal of the drivetrain, but it came out pretty easily.
Note the generous amounts of kitty litter on the ground. Gotta drain diff fluid before dropping assy next time. When the axles get pulled out of the trans, and you wiggle the whole thing side to side, she tends to puke out the oil.
It's beyond me how some of this junk ended up on top of the diff, short of being deposited by a critter. All components will get scrubbed before going back in the car.
Separated the diff/torque tube/trans from the subframe - it's only held together with 2 bolts. The centrally located diff mount does a very poor job of holding a rigid connection between the subframe and drivetrain.
I don't want solid mounts in this car so one of these is definitely in my future
So we finally have all this junk
Tucked away so wife can have her spot back until parts start coming in.
The plan right now is an LS7 clutch combo, torque tube rebuild (guibos, bearings), and a 4.10 diff (either send my stocker out or get my hands on a DTE built unit). Anything that doesn't look ok will get replaced with OEM or better parts. I'll probably end up modifying the C6Z06 shifter to have no slop as well - the lower box bushings wear out over time. Already have the Tick clutch MC but I'll replace the slave with a new OEM and throw in a remote bleeder too.
If I really get bored I can investigate the T56 internal centering detents - the 1-2 position snaps back to neutral just fine, but the 5-6 stays put in between those gates unless you snap back to 3-4. The external linkage to the T56 also has some tiny amount of slop in it, but that translates to much more when you multiply by the length of the shifter. I guess I was just spoiled by BMW shifters in the past.
