Hi,
I would like to ask the ff.
1. I've recently set-up my rear to negative camber. but from fender distance was quite far from the lip of the mags or tires. should i use spacer? what size? my mags specs is 15x8 offset 20.
i also tried to put two 1/4 spacer not still theres a gap.
2. do you cover your oil pan under? etc for protection
any tips in setting up stance car?
thank you
thank you
