https://www.instagram.com/jb_maf/ For updates and other fun car stuff!
Sticker for edge lit window is done, just need to sandblast. Mounts are installed, wires are trimmed and fastened, air lines are tidied up and grouped together. I made a mini manifold redirection block to keep the lines straight and it looks good. Mocked up the battery, just need to screw amp rack and run wires to amp and from amp to sub box location. I bought a press button toggle that will open and close a cylinder that will in turn open and close the trunk setup from a remote location not yet decided. Testing cylinders to see which one will do the job. I picked up a nice pfaff sewing machine and will be putting it to use for the diamond pleats and other stuff.
Where the hardlines become flex:
Machine:
Toggle button for opening and closing hands free:
Cleaned up a bit:
Air lines flow under amp rack:
Air lines continue behind bumper:
Sticker for sandblast edge-lit window:
JbMaf (Jason Bos Machining and Fabrication)
Machine:
Cleaned up a bit:
