Bit of an update!
Had a few things done..and address some problems..
So firstly, i got my tyres fitted last week.
And onto the car they went! no inner clearance issues
rear fitment:
front fitment:
Fitment is spot on and very pleased with how it all turned out
Im did some calculations, i need to drop the rear 5cm and the fronts 8cm to get it sitting nicely..i'll look into getting some custom springs made up for the time being
I then fitted some venetians to the car, giving it a classic look. I like it!
The top bracket was sticking out too much and i ***** how it didnt sit flush with the window as seen here
So i had to modify it and shorten it..looks much better now.
The kit also came with a module and motor for it to open and close automatically however the module is so retarded that i got rid of it and just made it electrical with a rocker switch to open and close it.
I've tested that its all working but have not hooked it up on the car yet. Will update when i do..
And here comes the problem i encountered. So my clutch master and slave cylinders had it. It was fking dangerous when it happened as i couldnt change gears and had to drive the car home in second gear..
The car was out of action for about 2 weeks as i had to order the master from the US off ebay and the slave from ECS tuning from my mate.
I got the master last week..and fitted it up. As you can see, the new one is abit different in design. The inlet is in the same position however the outlet isnt so i had to bend the hard lines to make it work. Check how old and broken the old one was..
GONER!
So after that was fitted, i ordered my slave cylinder from ECS tuning through my mates at BMR. While i was at it, i grabbed a Haynes manual and some clutch and brake pedal pads. It took awhile but it finally arrived today..
I decided i to fit the slave cylinder since the cars been sitting around doing nothing for two weeks..and again..........the slave was completely fked. The rod had fallen off, no wonder it was letting so much air into the system and not engaging.
Fitted, and bled the system and now the cars back to normal. Engaging gears as it should!
Also took these for fun while the front end was jacked up. Pretty much how i want the car to sit when im finished it with it
Sorry about the long post.
rear fitment:
front fitment:
GONER!
