Over the camber, after all I just got my M119 working properly again why not use it right?
I'm basically going crazy at this point with this car so it's time to seriously change things up.
New Plan:
0-4 degrees of negative camber in the rear
5 degrees of negative camber in the front
326 power wing
New bumpers, haven't decided on what I want yet
BN style side skirts
Molded flares
255/35/18's as opposed to 215/35/18's in the back
Saab shocks and raise the rear a little
Full poly subframe bushings and upgraded motor mounts
W124 LSD that works with the M119 (500E)?
Rear window valence
60K springs front and back (original seats calm down)
and headlight lean fix for all you perfectionists
Got some new parts and stuff like that, basically everything is going as planned with the parts I ordered. Oh and I had a tire blow out because I was riding on the sidewall (thanks Nexxen) on the freeway and lost control but I didn't hit anything and didn't damage the wheels or anything, fml tho. Probably not gonna update till I get some of the more drastic things done because I know some people's hearts on here can't handle it, Anyways here some pics of what's going down now you put the puzzle together.
I was stranded for 2 hours! in 90 degree weather with no AC, rad.
So hot
Everything should be perfect!
My "spare" is getting put to use lol
Will also be doing a vented fender and the rear doors will be incorporated, go ahead say it.
Now to just figure this out lol... hopefully with modded plates, I can get some angle from the front.
thought I should let SW know that this build is completely changing. ta ta
New Plan:
326 power wing
Molded flares
Rear window valence
So hot
