in for more. this is interesting. Also I'd say it's easy to know if it's armored or not by removing the door cards??
Vip Bagged Mercedes S300 w140 build :)
i don't want to take out the cd changer..i use itOriginally posted by z168 View PostI agree. There is room both sides but more so on the left side if he decides to dump the cd changer. Its big enough to stuff 2 shoe boxes in there
) i think ill leave the compressor there, it will look nicer when it will be all finished
behind the doorcards is a rubber/foam like material, about 2 cm thick glued to the metal sheet of the door......Originally posted by Meeve View Postin for more. this is interesting. Also I'd say it's easy to know if it's armored or not by removing the door cards??
Looking really good man, one question though.. Did you end up fitting those LEDs to the 140? Its just that it looks like you have the post facelift lights (rounded curves on the boot lid instead of a straight angle). Which i didnt think would fit your car without some modification or a post facelift boot. I only ask because im desperately trying to fit some LED lights to my 93 s320 :\ good looking tho famLast edited by mercin; 11-21-2015, 05:42 AM.
i did not fit them yet, but i am 100% sure they will fit... the car is facelift, and the led tails also, and optically they're identical...Originally posted by mercin View PostLooking really good man, one question though.. Did you end up fitting those LEDs to the 140? Its just that it looks like you have the post facelift lights (rounded curves on the boot lid instead of a straight angle). Which i didnt think would fit your car without some modification or a post facelift boot. I only ask because im desperately trying to fit some LED lights to my 93 s320 : good looking tho fam
the us trunk lid however will need modifications to fit...(it is pre facelift)Last edited by low_unit; 11-22-2015, 01:34 PM.
Finally managed to install the airride gauges in the upper compartment.... i think it looks classy and stealthy....next up the switches
Lid closed
Lid open
I ran into a problem....a whole lot of water in the front passenger footwell... where could it come from???? everything is soaking wet....I did not drive the car when raining( i never drive it on rain, not even on wet pavent) but i stayed out of the garage for the last week....
Yep, sounds like a heater/airconditioner problem...Lucas
You should put it higher up, next to the climate control, no?Lucas
nope, this is the original mounting position, however there is another model that fits parralel to the dash trimOriginally posted by loekaaz View PostYou should put it higher up, next to the climate control, no?
Wow that is awesome! Perfect!Lucas
