this is all great man. i love the raised rear arches
E36 Sedan SSR Mesh built
startet with the intercooler piping
and got my new suspension setup.
KW Clubsport coilovers, because i want the car to be trackready, just change the wheels and have serious fun at the Nürburgring for example.
it was used, so i complete stripped and cleaned it. i have to shorten the rear dampers and change the springs all around for more low and more stiffnes because of the heavier engine.
WOW WOW WOW!!! Amazing, a browny / purple thing on the first page to this absolute beaut, love it :-)My BMW E36 318ti Steel Blue Compact build thread -
Whelp right when I thought I couldn't read another e36 build thread you go and do this...
Sent from my iPhone using TapatalkS4 Avant - Build ThreadOriginally posted by s t a y g o l dand don't trash talk people, that's for hos at the club.
little update
got some new uprated springs for the rears. I choose the H&R because they got the shortest ones -> 80mm, KW only have 100mm.
For the springrate i raised it from 115N/mm to 130N/mm. Not the stiffest setup because it have to work fine at the Nürburgring.
here is a quick comparison
no i have to solve the Problem with the waaaaaaaaaay to long KW dampers
i think i go with a rebound setup and the raised top mounts from Groundcontrol or maybe i fabricate some with uniball bearings.
then i painted the car, my first attempt ever, turned out not that bad luckily.
VW Tornadorot
maaaaagiiiiiiiiic
and then started a bit of sanding and polishing, very much work but its worth it.
the i mounted the coilovers and anti roll kit
put in on the ground to see if the rear springs are low enough
love it <3
ouh and i got me some new racingseats
aaaaaaaaaaaaaaaaaand mounted them
this thing is pure awesome!
Originally posted by BozoBubbleStance bug bites hard, man, you ain't gonna shake it.
Truck Build
Instagram: somestancekid
