had a late night jam session on the car to get things done so i can focus on the injectors and intake manifold this weekend. Was able to get the Oil pan, and smaller pan section [no idea for the formal name on this] seals replaced and parts cleaned, did the valve cover seal and grommet and cleaned up the cover, and rebuilt the power steering pump. Was amazed at how easy the pump was to rebuild.
I think I am just going to break down and rebuild the turbo since they are near impossible to remove once in the car. The only things I should have left on the engine maintenance is the turbo, the injectors, intake and exhaust mani seals and I should be ready to put her in the car.
Found an oil leak on the drive side of the motor, so I need to trace that down. Number 3 diesel injector is still leaking, so hopefully I can pick up a new seal and address that....getting closer and closer.
