Um.... I don't really know how to tell you this, but all factory cars have a small amount of negative camber. It helps with handling and tire roll in corners. Factory specs usually range between -.5 and -2 degrees, and if you have independent rear suspension, any compression over the rear of the vehicle will increase the amount of negative camber while under load.
tl;dr your car is just stock...
