So my mkiv jetta plans have changed alot since i bought my car, i run oem longbeaches atm. And i am buying raceland ultimos in the next few weeks, problem is.. If i slam my car on the longbeaches, they will rub and scrape. So i decided to go with 10mm in the front and 15 mm in the back while i have my long beaches. Then the plan is to buy these jeep wrangler wheels that are 17 x 7.5 and 5x127 lug pattern. And a 71.5 centric bore. I have no f**cking clue what any of those numbers mean.... BUT all i can do is ask for advice on, 1: should i need wheel spacers if i buy wheel adapters? And what size adapters. I would **** to buy spacers for my oem wheels then not be able to use then a month or two later because of the different sized jeep wheel. Let me know guys thanks
Something different/interesting for an MKIV.
You're gonna need adapters for the Jeep wheels because the Jetta bolt pattern is 5x100, not 5x127.[CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
[img]http://i.imgur.com/hNTlNvf.jpg?2[/img]
Instagram: [url=https://instagram.com/divingboardlord/][color=red]@divingboardlord[/color][/url][/CENTER]
That's gonna bad ass. They will fit but with some fender rolling and lots of camber.
Originally posted by smarty98 View PostI might just buy some damn sawblades at this point
Oh and BTW, you are still gonna need adapters for the sawblades also, so if I were you I would not buy any spacers / adapters until you are sure of what wheels you want and how wide you want to go, because you will need to base everything else off of that.[CENTER][url=http://www.stanceworks.com/forums/showthread.php?t=66924][color=red]e28 build thread[/color] [/url]
