Originally posted by hinrichs
View Post
Audi A1 by mgpdoc ••
So, this is the place we will be working on for this post. This, and the EGR system.
Dpf by mgpdoc, on Flickr
Here's an idea of the crap that goes inside your inlet on a diesel car with just 28k miles on the clock. Sad is it not ?
De-Dpf exhaust install by mgpdoc, on Flickr
Block of plate to the rescue
EGT sensors off
Lamda Sensor off
After A LOT of fiddling and swearing, the downpipe came off
Not in piece sadly as for this to happen probably all the subframe would have to come off so ef it.
First test fit
TB block off plate - will change to matching bolts later
Downpipe path
Here is where it got tricky will get to that later
Final dp part which is modified with a v band to match the rest of my 3inch cat(what cat lol)back
This is the part where we had clearance issues. Downpipe touched the steering rack. Ofcourse, once again, bolt on fitment wasnt the case
So out again to modify it
Reshaped it and it was great afterwards
Matching bolts as promised
Sensor on
These however had to be left plugged and tucked in place, cause the car cannot work without them. Even after the ecu remap. Will see if maybe at a later version.
This map sensor of the DPF was removed though
Untitled by mgpdoc, on Flickr
Egr and boost pipe removal by mgpdoc, on Flickr
As was this EGR part from the Exhaust manifold to the EGR
Car was a little rolling-coal happy
But nothing a wash and wax cant fix
Then i decided to remove the complete EGR assembly as it was no longer used, to save weight and clean the engine bay even more
Oil return line has to be removed
And you have to make a U-joint for the water pipes that run to the coolant radiator of the EGR which is also removed. Luckily i had the U-joint from the A4 hehe
Blocked this hole as well
And this is what was removed
Then, we remapped the car, it made another 10hp but we havent finished yet, will get back to you with more results once we fine tune it
Big shoutout to etuners greece, and Stelios Alexandrakis in particular.
Cheers
More to come
Havent had the chance to clean the internals of those parts yet, but at least i stopped its becoming even more in a very early stage. At some point though, it will be cleaned properly.Originally posted by C2_mad View Postwanting to do the same thing on my bmw e90.. cleaned the intake manifold and egr. it was full of crap. removed at least 1,5cm of crap all around the inlet.
So, truth be told i was pushing my luck somewhat
In the past i entered the sea with the Cherokee pretty ofter at this particular spot. However . . .
This is not a Jeep
Got pulled out by a family car, but not without my pride and my car being hurt as well. AC radiator got pushed by the bad Darkside IC installation probably, and also, wheels were scratched from the rocks at the beach.
Had no Ac for the next days, and scratched wheels, oh well
On my way back home, at a highway parking
Got back to Athens, and lost no time
First AC radiator replacement, and new mounting points and brackets for the IC, properly this time, and not like my half-ass job on a bad product
All done and I love how the new BEHR Ac Radiator is silver instead of black
Looks mean
Temporary Audi wheels while mine were sent to be painted
Gave it a proper wash
Do these wheels make it look like a Renault or is it just me
I also ordered this Powerflex mount - Diesel Specific - To reduce engine movement which was getting frustrating especially after the track visit.
It increased vibration, but reduced movement like it should
Powerflex by mgpdoc, on Flickr
Oem
And then wheels were ready
I opted for a change to see how it would look. I normally like to keep my cars in a two tone theme. And this is no exception, it was red and black.
However, i thought I'd give it a go on something rather different.
So. . .
Gunmetal Wheels by mgpdoc, on Flickr
This is what I came up with
First time on the car
Gunmetal by mgpdoc, on Flickr
They sure look bigger
To be honest at first i couldnt get used to it but the more i saw it the more i liked it
Threw on some Rota caps in Gunmetal which I ordered from UK again
And the box as well
Summer by mgpdoc, on Flickr
Car is currently away on vacation mode, seeing some dusty roads and beaches
Cheers
Mike
New wheel color looks greatMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
^ this picture made me do a double take. I thought you added another sticker. lol^
The new wheel color looks perfect. I like it better than the black.
Some more updates then to try and bring you up to date, since my lack of time is bigger than ever due to my job.
Some shots after i washed the car on early september
Befores
Post summer wash by mgpdoc, on Flickr
And Afters
I loved it
but, the shade of gunmetal i think quite the perfect one. I just couldnt get it out of my head. to be honest
Car agreed
So, again, onto temporary Audi wheels to get my wheels repainted in the correct shade of gunmetal
Re-Refurb by mgpdoc, on Flickr
Car was looking funny once again
Also bought me a new KArcher machinery
Octoberfest by mgpdoc, on Flickr
Gave my engine bay a good clean, as well as my mate's S3
Results
Next post we are gonna see how the wheels turned out and many many more things
Cheers
Wheels were then ready
Boom
Now we are talking
Red caps and gold letters were an idea that came to my head this time
Came out awesome although the painting on caps coulda been better in my eyes. Wheel powdercoating was perfect
Threw them on the car
In my opinion, best look of the car so far
Cheers, hope you like them
Another thing i ordered is some proper Recaro Subframe seatmounts for my car, since the ones i had were Recaro again, but for an Audi R8 it seems.
Proper quality as always
Installing the mounts is a bit tricky. You need to unbolt some framing off the oem seats, and u use it in between the chassis and the Recaro frames. As always pics will do the talking. I used completely new hardware everywhere and blue loctite to be safe like i have done in the past in my other cars
Part from oem seat needed, practically the slider
Seat mount and pads by mgpdoc, on Flickr
Start combining the two
Remove old Recaro mounts
Clean canvas
Test fitting the new ones
New bolts on side frames
And ready to test fit
Dont forget
Looking much better and much safer
The car also had its programmed maintenance schedule
Oil, Oil Filter
Front and rear pads although they did not need to be changed
Wish I had the time to install the Porsche calipers someday though....
And also made some more orders
But more on that, on the next post
