Test fitted the new 15x9 wheels. might need to run a 5mm spacer since its quite close to hitting the spring up front and some subframe bolts in the rear. i guess that what happens when you got racecar offset on a stancecar.
Nice work so far, surprised this hasn't gotten more attention. Do you plan on keeping the stock body work, or going with bolt on fender flares or some sort of kit?
Maybe you could do something like this NB? Check out his 1.8 engine build.
ordered some more stuff I guess. spaced the fronts out 5mm. still need to finish rolling the rears before putting 5mm spacers on those.
Also ordered a garagestar steering rack spacer and windshield banner. goin full racecar!
and picked up some local cheap ebay Emusa coilovers, hopefully can get these lower than i am now and will last until I can afford BC coils.
tiny update: got some 20mm spacers on the rear,only have 5mm up front, thinking of bumping that up to 15mm.
also picking up a Torsen LSD this weekend to get rid of my weak 1.6 open diff.
