BMW E28 'Low Wheels'
  • BMW E28 'Low Wheels'
    Hello!
    I from Russia, the Republic of Mari El long to read blogs on STANCEWORKS especially the subjects BMW E28 dovno wanted to write in your subject about the car but all the same solved if the subject awakes I will be demanded to continue to write, so far all!!!
    About my car
    The history of the auto-m 1994godu begins in the summer when she was driven out of Germany by Car Cheboksary own grandfather and bought it there
    BMW 520i E28 automatic transmission.
    And before it was all 2007year his grandfather in g.Kozmodemyansk once it fails to start after the winter, the winter did not go the reason became oxidized mass, and passed through the brain as a result of the car was tackled to sell but it was impossible to sell the cause of uneven pace no traction when buyers came it did not take iza etogo.A as she stood in the garage until a friend of his grandfather offered to exchange the bMW on milling machine, and 2007, it gives the car a friend he was looking for a donor finds it buys in Nizhny Novgorod and changes the brains and everything he goes on it .
    In 2011, he sells it and the donor in Cheboksary girl Anna is due to pregnancy decides to sell it after winter kicked her out of the garage and took a photo posted on cars py well, there actually I accidentally Founded grandfathers auto m.Uznal car once it has been the same equipment and the same cassette was not nothing changed in the interior of the car, I called the other day that I agreed to sell its 100% prepayment threw her to remove all edn and after a couple of weeks 8maya I bought it!
    According to Title I 4th host of them third Ure. my grandfather Jura, one grandfather Jura Jura and I well and girl Anna.
    P.S. That returned the car I wanted and did not think that her grandfather would sell and I find her sluchyayno!
    Wheels Remotec R17 (Borbet A)
    Hi Everyone!
    For a long time did not write anything, I will tell you that bought wheels Remotec R17 7,5J ET 20 - 9J ET 8 in very plachebnom state as the owner, he told them last blasted and painted.
    Well, it was decided to polish the shelf with nachil
    - Skin Flap
    - 120
    - 180
    - 320
    - 400
    - 500
    - 800
    - 1200
    - 1500
    - 2000 (all water)
    - Felt (cut a piece of Valinco) pasta goy and kerosene.
    See the result on the same wheels were all the same shell from sandblasting may drive again will grind etc.
    In the future I will paint in the center of the birch until determines the color of the lid and wait.
      Suspension bracket + Wheels
      All Hi!
      Generally I put a screw suspension bracket of DGR dgr-russia.ru/with adjustment of rigidity of 30 provisions now in the soft mode very comfortably I would tell, everything norms is pleasant but there is 1 minus the back lower not to lower and before even it is possible 5sm as so ((((already I think of alteration of holding midfielders and to put pro-rates on forward wheels of mm so 15-20 and disorder 1/1,5 degrees.
      On installation of problems there was no everything easily and simply.
      Before approximately on 10sm the back on 5
      Also I collected wheels of Remotec R17 7,5J ET 20 — 9J ET 8, Triangle 205/40 and 215/40 rubber.
        Excuse for my English!
          I put deliveries on before 30mm and after I made a few photos!
            Nice car, what brand of tires are u using on the remotecs?
              nice! can't wait to see whats next!
              1987 325is
              1988 528e
              #30Furdayz
                  Hi, everybody!
                  This record at the request of owners of E28 to problems with a priborka. As Vobsh upon purchase of a car the speedometer didn't work the odometor and a flowmeter plus temperature of the engine and a gasoline tank occasionally twitched.
                  I decided to sort a priborka and to understand what matter in a result having opened a priborka the oxidized accumulators which began to flow were found and for it the payment some paths simply was oxidized corroded and someone tried to restore them. As a result выпаял accumulators also I threw out them (having read in a network that accumulators served for food of memory of replacement of oil) I washed away an oxide usual water accurately not мочив radio components, пропаял and which were torn restored paths conductings I rang out a toaster and I covered with nail varnish, the loop too drank and on a loop I pulled out contacts in a green block and cut off an old loop and soldered to each contact new conductings where soldered covered with nail varnish that suddenly didn't touch each other and soldered to a payment. Having still looked through attentively on a payment it was revealed a little badly the propayenykh of details.
                  Instead of hours I put a tachometer.
                  Photos a little as didn't think that it is required to someone to eat questions in h.p.
