This may take awhile, introducing one 1966 Toyota Corona
have you had anymore luck with windshield hunting?
I didn't know if anyone asked but is this a 4 speed or 3 speed?1976 VW Beetle
Eine Gruppe für Menschen, die am Heizkörper spotten
do you know if later models are backwards compatible?
the direct ebay shop is here: http://www.ebay.com/usr/bkclassicautoglassLast edited by TheSavoy; 07-25-2014, 12:12 PM.1976 VW Beetle
I think you might want to go the lexan route. It's only like $100 a sheet. Just don't make it too thin though. Also, you will have to put the lexan on the window frame first, get a rough cut, and keep refining the fitment as you don't have original glass to use as a template. To waterproof it, you will probably have to seal it on with window weld, and use rubber trim around it. The lemons guys use rainx and apparently it's good enough
This will allow you to shave the windshield wiper holes as well, and go for an old school racer look.
As for an engine, have you considered carbing a 5m or 7m? They are available on the cheap, and the carbs will cut down on most of the wiring needed to run it. Also, they are based on the original M engine design from the 60's.Last edited by rice4life; 07-26-2014, 02:37 AM.
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
