sweet sweet car, ever since I first saw a pic of this I've wanted more.
Bmw 535 e28
The front seats will bolt in with few holes and a small lift but you need to narrow the rear seats ~5cm to fit it properly and make some new mounts for the seat and belts.Originally posted by nyman90 View Postabout the interior question, I have not installed it yet but when I do, I will tell you what needed to be done
On the finnis BTCF page a guy has done it allready, here youŽll findsome pictures and measurements. , actually a few have done it, i just canŽt find any more threads now
E34 m5 seats
ThanksOriginally posted by Leksii View PostThe front seats will bolt in with few holes and a small lift but you need to narrow the rear seats ~5cm to fit it properly and make some new mounts for the seat and belts.
 I know roughly what to do
Wow. Awesome build!! Awesome looking car. Wery excited about V8 swap as I'm planning to do same thing next year. So please post as much info and pictures as possible
What gearbox is that? Manual 540i are impossible to find so I'm wondering what to use...
Hi, huh awhile since I wrote here now and it has happened a lot, I had to take a break from v8 construction work because I wanted to get out and run a little bit and I could not clear the M60. so I got hold of a 528 I took the engine and gearbox from and mounted in the mine, had stood for many years but worked perfectly! v8 construction work will soon start again when the summer is over.
The 528 i took the engine and gearbox from. It had ac and cruise control also
