Originally posted by dvious
View Post
Supseb's Porsche 911 Build *PIC HEAVY*
I have a 15mm spacer waiting to go on the rear. I'll post pics later but I can't run them yet because then it rubs on the rear bumper believe or not, lol. I need to have the bumper tab cut to fit them.IG: @supseb
Porsche 911 (996)
Mercedes-Benz w115 240D
Looks really sharp with those wheels! One problem though... You mentioned wanting custom 3 piece wheels but you are modifying the car for those wheels... That means the wheels you have custom made will need to be exactly the same size right? Or will you just re-modify the car to fit the new wheels?Slowly modifying a VW Bora to my taste...
Yes sir. The new wheels will be made to the offset of my HRE's minus 15mm (for the spacer im putting on them) The fronts are just using a simple fender roll, no crazy work. Here's how they fit with the 15mm, spot on IMO.Originally posted by e30chris View PostLooks really sharp with those wheels! One problem though... You mentioned wanting custom 3 piece wheels but you are modifying the car for those wheels... That means the wheels you have custom made will need to be exactly the same size right? Or will you just re-modify the car to fit the new wheels?
IG: @supseb
Porsche 911 (996)
I don't know the offsets because they have been worn off but I am almost positive the rears are 18x11 et47, after the 15mm spacer will be 18x11 et32. However, I still have not gotten around to trimming my rear bumper so the spacers aren't on just yet.Originally posted by geeky View PostWhats the rear final ET/rear wheel specs?IG: @supseb
Porsche 911 (996)
