seeing your cars at bimmerfest was rad. so stoked to see how this comes out. judging by your previous builds im sure its going to be ridiculously awesome.
CAtuned E28 Build
Thank you for all the kind words and great feedback.
Update: Coilovers on the front got welded up. Coming together. Just been rather busy in the shop with customer work and havent had the time to do as much as I'd like.
Also a powder coated rear Differential Cover
Rod bearings came in for the S52
**** Also wanted to share some interesting stuff.
If you have a E28 and you want bigger better brakes in the Front with out spending $1800 on a BBK kit.
You can Get E36 M3 front Calipers with brackets(Or E34 M5 calipers with brackets but E34 M5 units do not have the //M on them).
The Setup:
1) The driver side E36 M3 Caliper with bracket bolts up on the passenger side.
2) The passenger side E36 M3 Caliper with bracket bolts up on the driver side.
It is a direct fit.
3) For rotors use the E34 M5 Rotors they are floating and 315MM. You can't use 15" rims with this tho.
Pictures from test fitting. Rotors shown in the pictures are stock e28 so ignore those.
I will update the thread when the Stoptech Rotors show up later in the week.
We have the coilovers installed. With new Hubs. And resprayed the Dust shields
Have the tires on the rear wheels. I think it looks good. Need to attach to the car as soon as the rear end assembly is back on.
Engine is coming together (s52)
Then again we do have a perfectly good, Low miles S54 just sitting in the corner begging to be put in.
Hmm
Thanks!Originally posted by 99sil-teg View PostThis thing is going to be so badass
Has been done 2 times that we know of. 1 in Canada and 1 here in the states. were 99% set on doing it.Originally posted by xXp_ExoTiic_qXx View PostDamn, you guys should do the s54 swap, have not seen that before.
Anyway keep up the great work!
The Rotors we ordered from Stoptech came in:
You can see the difference between the stock rotors and the upgrade.
