Rogue Warrior
  • Frame notch completed this picture is with the tire sitting on the bumper tab and the inside of the rear door so anything thinner than 245 should solve that shooting for 225/35 but well see where it goes.
    Build Thread
    Static Nissan Rogue
    Instagram @ksc.jz
    • Good to see you still wrenching away on this thing. I need to make some form of progress on my car. Le sigh.
      MB Obsidian Black Metallic Crossfire SRT-6
      Instagram - @osshwa
      • Originally posted by OSSHWA View Post
        I havent made progress all year, Ive just recently been motivated to do something to the car looking forward to crossfire progress tho
        Build Thread
        Static Nissan Rogue
        Instagram @ksc.jz
        • My 34k arrived yesterday. Put everything on in the same day, just have to cut a few things in the wheel well.
          Notched the bottom mount to add more camber
          I had to redrill the top hat holes on the passeger side again thats why it sat so high on this side in the past, but i got them on and maxed the camber. These wheels are 20x10.5-11 after spacers.
          Ill be sure to keep updated
          Build Thread
          Static Nissan Rogue
          Instagram @ksc.jz
          • Im having an axle binding issue up front after the camber, anyone know a fix that doesnt invole removing camber?
            Build Thread
            Static Nissan Rogue
            Instagram @ksc.jz
            • Solved the nimding by reducing the camber but i need new axles. The motor is now raised aboput 3/4 of an inch. Loving the 34k 5 inch springs. I think im able to run 19s this year
              Build Thread
              Static Nissan Rogue
              Instagram @ksc.jz
              • this is pretty cool man, i love seeing "odd" platforms being used. keep it up.
                • Is there a way to pull the back of your rear quarters and get the bumper to come out as well. They just seem very pulled and then come back sharp at the bumper
                  95 318ti & 96 328is
                  Compact Build Thread
                  • Originally posted by roboro View Post
                    Thank you!
                    Yea there is a way but I was going to do it when i got the new rear so im just procrastinating
                    Build Thread
                    Static Nissan Rogue
                    Instagram @ksc.jz
                    • The new rear? Like a matching rear to go with your front bumper?
                      95 318ti & 96 328is
                      • Originally posted by Earl View Post
                        Yes sir
                        Build Thread
                        Static Nissan Rogue
                        Instagram @ksc.jz
                        • Originally posted by kingshowercap View Post
                          I feel ya. Nothing has changed with my car in a while. I've only driven it once so far this year. But that's all about to change. I have some new aero parts on their way, new wheels that will be coming soon and i'll be having the car resprayed again (same color, just a better paintjob).
                          Instagram - @osshwa
                          • Not really a big update I have a couple parts I want to get on just waiting on a warm, clear day but this is something I wanted done since 2013 but never got around to it, or forgot really.
                            Morimoto Mini H1 with mini Gatling shrouds
                            Instaled by the same guy who painted my housings/reflector. Havent gotten them yet so first chance I get tomorrow.
                            Build Thread
                            Static Nissan Rogue
                            Instagram @ksc.jz
                            • Nissan Rogue projector retrofit. Ill post the cut off pics after I get the 55w ballast.
                              Build Thread
                              Static Nissan Rogue
                              Instagram @ksc.jz
                              • Looks really nice, doesn't look like an suv anymore. As for the axle binding you either need to extend the lca's or shorten both cv axles. Best bet would be find a confident welder to extend your lca's 1/2-3/4in near the ball joint. Good luck man!
