i love these little cars
Project Dirty Dimepiece
So here are the differnces between the stock Mitsubishi 18g compressor wheel and the Kamak STS billet wheel. The kamak is obviously taller which is supposed to pull more air. It is also lighter than the cast stock wheel because of its smaller center. Less mass in the middle, larger blades and more surface area on the blades. Also there Are less blades total but more blade surface area
As you can see there is much more blade on the the Kamak STS wheel and has less mass/weight in the center.
Same concept with the exhaust wheel. Small center, less blades, less rotating mass but more total blade surface area and higher flowing. I have read on other forums that this exhaust wheel flows/power like a TD06SL2 with the spool characteristics of a smaller turbine. I won't have a baseline for comparison when I post dyno graphs but it should perform well and produce the numbers I am looking for.
