BMW E92 335i - progress thread
  • Originally posted by stbk View Post
    Gonna do this in norwegian.
    Hvor har du henta styrestrøm? hadde lignende problem med mitt V2 system. da hadde jeg henta styrestrøm fra en plass jeg ikke husker helt, men det gjorde i allefall så jeg ikke fikk brukt preset mode og det starta opp av og til av seg selv.
    Jeg har henta styrestrøm (ignition) fra 12V uttaket i bagasjerommet. Sigarettenneren om man vil. Brukte samme sted når jeg hadde e-level. Jeg har også prøvd å koble til ignition direkte på batteriet men hadde samme resultat da også.
    Har også gått over alt av jord og +ledninger. Skjønner ingenting.
    '18 BMW F80 M3 San Marino blue / Amaro brown
    instagram.com/frodedale
    • I actually brought my camera with me to the garage this time but did just snap a few shots.
      The back of the tank:
      Full of MDF-dust after fabricating the trunk floor. Does not go low enough with 19"
      • Man that looks amazing!
        R.I.P P.WALKER 2013/11/30
        • Originally posted by 244Brick View Post
          Thank you!
          • how are you liking the autopilot v2 so far?
            I'm deciding on what management I want and I'm just curious as that is one of my main contenders.
            Not to mention I have an E92 335i as well and I have been watching how beautiful your build is getting.
            Thanks for any info!
            • Haven't really used it yet. But it is so relieving to not worry about the sensors breaking or giving signal errors, and having even pressures on left/right. I like it much more than e-level just because of its simplicity.
              I would go with V2 or Switchspeed if I were you. I have several friends with V2 and they are all happy with it.
              Thank you.
              Edit: The relay on the OB2 was causing the V2 to restart. Finally found the fault!
              • Originally posted by Frode D View Post
                Thank you.
                Thanks, I wouldn't want to go with the Switchspeed vs the V2 strictly because you get so many presets with the V2 so you can have multiple presets for different weights/heights.
                • Originally posted by BRD1234 View Post
                  True. It's nice to have 8 height settings available.
                  • Just gonna leave this here
                    • Futuras were better
                      Real name is James
                      • Ohh fuuuckk, moar!
                        • Originally posted by KarlSpackler View Post
                          Futuras were better
                          Maybe, but to common...
                          Originally posted by SliPsY View Post
                          Ohh fuuuckk, moar!
                          Don't have more pictures. They will shipment next week.
                          • Haven't posted here in a while so her comes an update.
                            Wheels are not here yet, but the trunk is finished.
                            Painted the air tank "BMW Frozen Grey" (same as wheels). Wrapped the whole trunk with alcantara fabric and made a new false floor. First attempt on the floor was with 4mm wood, 5mm foam covered with fake leather.
                            This looked hideous so I made a new floor with 9mm wood, no foam and alcantara fabric. I also covered a bigger part of the subwoofer for a cleaner look. I'm happy with how it looks now.
                            And the final result:
                            • looks great man. gonna polish the lines? id make a plexi cover to go between the lines and false floor. maybe add some led's around the edge along with it, also Chamfering the cut out for the sub would be a nice touch.
                              @DollaDollaDill
                              • Thanks! I'm not a fan of plexi and leds, but chamfering would be a nice touch indeed.
