Nice, it looked like you were over in Savannah with the trees and all. I went to GSU and GT savannah that's why I asked. Have you taken out the collars of the rear? If you can't go any lower, you could always get a set of swift springs
Keuropean Trash
Cut the rear springs. That's what most of the people on Megan Racing coilovers do to get the rear end lower.Originally posted by brandonxdent View PostI'm in contact with megan racing now, that is maxed out in the rear on my coilovers so I'm trying to figure out HOW i can go lower without just getting crazy rake (which is ugly). Overall though I'm pretty content with my ride height for the time being.
And i'm down in valdosta GA. Worst roads EVER.
As for the front, if you're maxed out, you can buy shorter springs with higher spring rates. You just have to call around for them.
Check out the thread on my bagged Forte 5 when you have a chance here.
Bagged Kia Forte 5 Build HERE
They don't make any for the rear of our cars. They do make some for the fronts though.Originally posted by fifty3bags View PostNice, it looked like you were over in Savannah with the trees and all. I went to GSU and GT savannah that's why I asked. Have you taken out the collars of the rear? If you can't go any lower, you could always get a set of swift springsBagged Kia Forte 5 Build HERE
I was under the impression that Swift can custom make springs if you give them the information. Like take off your megan springs give them a diameter measurement and height and what spring rates. I may be wrong, I haven't researched SwiftOriginally posted by _AnGeL_ View PostThey don't make any for the rear of our cars. They do make some for the fronts though.
Haha I love the yellow personally man. It seems like people either love it or **** it though. Thanks for the love!Originally posted by DaguerrotypeI View PostYay new car! Even though the yellow wheels are ridic I can for sure see something dope out of this build in the future. You got my support sir!
And if Swift can make custom springs ill be all over that, except its probably gonna be pretty pricey. May just end up cutting them who knows.Busted Knuckles Brigade (Coming soon)
#KDMstance
R.I.P P.WALKER 2013/11/30
My issue is the rear assembly has the weird "strut separate from spring" thing going on so the rear spring is quite big. Ill probably call Swift and give them some measurements and see what i can do. My only concern is that the strut combined with a different spring other than what its designed for would make for a bad ride.Busted Knuckles Brigade (Coming soon)
#KDMstance
Mine is the same wayOriginally posted by brandonxdent View PostMy issue is the rear assembly has the weird "strut separate from spring" thing going on so the rear spring is quite big. Ill probably call Swift and give them some measurements and see what i can do. My only concern is that the strut combined with a different spring other than what its designed for would make for a bad ride.
They've done that application before (anttmann had swift springs on his 135i I believe). Just get a measurement of the rear spring and contact Megan and see if you can get the shock specs and then send it all to Swift and they'll be able to help you out I'm sure. It is their job
Powered by vBulletin® Version 5.7.5
Copyright © 2026 MH Sub I, LLC dba vBulletin. All rights reserved.
