Hey boys, Looking for some advice as i picked up a set of 20" work vsxx wheels. I need help to try and figure out what i need for tire sizes. Any help and suggestions are appreciated as this is my first time trying to fit an agressive set of wheels.
What im running:
Front: 20x9.5 +17 10mm spacer (spacers are not mounted in the pictures)
Rear: 20x10.5 +13 5mm spacer (spacers are not mounted in the pictures)
Driver Side
Passenger Side
You be the judge but to me it looks like my driver side wheel sits out further then the passenger side, the only thing i can think of is that the camber is off slightly giving the illusion that the top of the rim sits out further. Like i said earlier i also need to run a 5mm spacer in the rear.
What im running:
Driver Side
Passenger Side
