No pictures with this update, mainly because it would be embarrassing. I cut 100mm out of the panhard rod. If my calculations are correct this will center the axle and allow the rod to be adjusted 30mm shorter and about 15mm longer.
I welded the other tube adapter on and it turned out worse than the first one.
I did not grind it down and showed a co-worker. He agreed that it was bad. He took both ends of the rod home and is going to cut out my weld and tig weld it. It is humbling but I will keep practicing and move on.
