Here is what I have done with my Jetta so far. I, along with a couple of friends, have done all of the work except: APR Stage 1 Software done at AutoMotion in Louisville, KY; Exhaust done at Performance Xhaust in Evansville, IN. Thanks for taking a look!
Newest pics are at the top, build/older pics at the bottom.
Vehicle Info:
2008 Volkswagen Jetta SE
2.5L w/ 5-Speed
Laser Blue Pearl
80K Miles
Engine:
APR Stage 1 Software w/ Fully Loaded ECU
APR Carbonio Intake
USP Motorsports Test-Pipe (Catless)
2.5" Magnaflow Exhaust w/ Magnaflow High-Flow Resonator
Suitcase Muffler Delete
R8 Red Top Coils
NGK Laser Platinum Plugs
Verdict Motorsport Shift Bushings
ECS Dogbone Mount Insert
Suspension:
AccuAir SwitchSpeed Management
Air Lift Performance Series Front w/ Adjustable Camber Plates & 30-Level Adjustable Dampening
Air Lift Double Bellow Bags Rear
Koni Yellow Adjustable Dampening Sport Shocks
5-Gallon Tank (Powder Coated - Black Pearl)
Dual VIAIR 444C Compressors
3/8" Lines
SMC Check Valves
AVS Water Traps
Frame Notch
Entire trunk has been completely done with FatMat Sound Deadening Material
Wheels & Brakes:
OEM Mercedes AMG Style 1 Wheels (Powder Coated - Black Pearl) w/ 205/45 Nitto NeoGens (Less than 7k miles on wheels and tires since having them completely refurbished - ZERO camber wear)
Front: 17x7.5 et37
Rear: 17x8.5 et30
OEM Brabus Affalterbach Center Caps
All new bolts and hub-centric rings from ECS
StopTech Cross-Drilled Rotors
Hawk HPS Pads
TyrolSport Stainless Steel Brake Lines
TyrolSport Brake Caliper Stiffening Kit
Motul RBF600 Fluid
Exterior:
Euro R32 Front End Conversion
OEM R32 Headlights
Morimoto 6000K HID Kit
Optikwerks Votex Sideskirts (Car is actually used on their site: http://goo.gl/65GSCR )
OEM Votex Rear Valance & Diffuser
Shaved Trunk
Eurogear Notchless Carbon Fiber Hood
Blacked-Out Window Trim
Tinted Mirror Lenses
Removed Rear Badges & Pinstriping
6000K LED License Plate & Reverse Lights
OEM Euro LED Red Taillights (Amber Club)
Blue Aspherical Mirrors
Interior:
Full Plaid Interlagos Interior out of an 08 GTI (Front and Rear Seats)
Color-Matched Interior Trim (Professionally Painted & Cleared in Laser Blue Pearl)
NewSouth Performance 3 Gauge Offset Dash Pod w/ Exta Air Gauges
OEM Euro Headlight Switch
Full 6000k LED Interior
Kenwood Excelon CD/MP3 w/ iPod, USB & AUX-In (Power Wire & RCA's are already ran for amplifiers & sub)
VCDS/VAG-COM Changes:
Amber LED Turn Signals Enabled
DRL Off
TPMS Off
Cold Diagnostics (for LED lights) Off
Seatbelt Warning Disabled
Flash on Emergency Braking
Window Roll Down/Up via Remote
Sunroof Open via Remote
Coming Soon:
New Stereo & Trunk Setup
Coming Later:
Turbo - Just starting to do research
Newest Addition: Full R32 Conversion Complete
Old Headlights
Old Headlights
Old Headlights
Round 3 - Euro R32 Front Bumper & Grill, Votex Sides & Rear, Shaved Trunk & Interior Trim Painted
Build/Older Pics: Bone Stock
End of Round 1 on Coilovers & RS4 Reps
Beginning of Round 2 - New Exhaust
Fatmat throughout the trunk
New plugs, coil packs, shifter bushings, headlights & HID's
Interior Trim & Side Markers Sanded, Primed & Painted
Laying out the air ride enclosure
Running cables & installing gauge pod
Air Ride, brakes & dogbone mount insert being installed
Damage from the accident
Frame notch in the works
Front brakes, bags & frame notch done
Rear brakes & bags done
Bumper Surgery. Zip-tie stitches and a bandaid make it all better. I traded my old factory chrome grill for this badgeless grill. It's not going to be on here permanently. It looks better than no grill and a busted bumper.
Cleaned up and aired out
Vehicle Info:
2.5L w/ 5-Speed
Laser Blue Pearl
80K Miles
Engine:
APR Carbonio Intake
R8 Red Top Coils
Suspension:
3/8" Lines
SMC Check Valves
AVS Water Traps
Frame Notch
Wheels & Brakes:
Front: 17x7.5 et37
Rear: 17x8.5 et30
Hawk HPS Pads
Motul RBF600 Fluid
Exterior:
OEM R32 Headlights
Shaved Trunk
Interior:
DRL Off
TPMS Off
Coming Soon:
Coming Later:
Old Headlights
Old Headlights
Old Headlights
